Can you spray 200HP on the NX shark nozzle?
T/A lt1
01-23-2005, 07:47 PM
I have been running the NX shark nozzle for along time (150hp) and want to try jet it up to 175hp (already have the 73N 41F jets) then if it hooks well I want to try 200hp if possible or should I just put 2 nozzles? I also have a NOS plate but don't know if it would be a good idea to run the NX kit and the NOS together. LMK Later Clint
MEAN_SBC
01-23-2005, 08:57 PM
The shark nozzle will spray up to 250 shot, so you're good to go.... :)
n20ta2
01-24-2005, 01:20 PM
Hmmm,im using A pair of NOS nozzles and they are only rated for 175 each,I would check with NX first.
MEAN_SBC
01-24-2005, 05:11 PM
The standard NX20920 will work up to 250hp. Anything above that and you have use a -4 nitrous line from the noid to the nozzle. 200hp is no problem with that kit. Just run good fuel and watch for detonation.
Ricky
Take Ricky's word for it.... :)
Checking with him, is pretty much checking with NX...
He said this in the following post:
http://web.camaross.com/forums/showthread.php?t=327774
LT4383
01-24-2005, 06:46 PM
What's the max on a piranha nozzle? Just curious
NXRicky
01-24-2005, 11:33 PM
200 no problem on the Shark, the Piranha is good for 150 and that is pushing it. Who gave you that tune up number?
Ricky
Derrick Redd
01-25-2005, 07:42 AM
I've done the 175 shot with good results on a single shark nozzle. I know a few people that have done the 200 without issues. Go for it. :thumb: :D
