F/S: 1995 Eagle Talon TSi AWD
EDIT: Still no bites and I need to sell. A 5% finders fee of sale cost if you find a buyer.
Picture Link
I know it is not a car normally on here, but it is fun and quick. I ran a 13.2 @ 99.81 on the 1/4 mile my first time at the track. 15lbs of boost and 93 octane pump gas. The car has a freshly rebuilt engine w/ aprox 1,700 miles on it, brand new transfer case, new belts and all that. I am stationed at Tinker Air Force Base in Oklahoma City and must sell the car because I am moving. List of mods below, any questions plz ask! Thanxs...
Chuck
Head
Cometic HP metal head gasket
1G head
3-angle valve job
ARP head studs
ARP exhaust manifold studs
ARP intake manifold studs
HKS cams 264/264
2G revised lifters
Ceramic coated valve cover
Block
Blueprinted 1G 6-bolt engine
Micro polished and balanced crank
New oil pump cover
New oil pump
New water pump
New Mitsubishi timing belt
Balance shaft elimination
ATR underdrive crank pulley
Intake manifold
1G Intake Manifold
Mustang 65mm throttle body
Non-cruise throttle cable
Exhaust
Full 3" mandrel bent exhaust
Dynomax Ultraflow straight-through 3” muffler
Ported 2G exhaust manifold
Ported 16G turbo
SS oil line
Ported 2G O2 housing
Intake
3” intake with K&N
2.5" mandrel bent IC piping
Upgraded side-mount intercooler
GReddy Type-S blacktop BOV
3" GM MAF and translator
Fuel
Nippon Denso 660cc injectors
Walbro 255HP fuel pump
Fuel pump rewire
Ignition
Accel 8mm spark plug wires
NKG BPR7ES spark plugs
SS clutch line
New master and slave clutch cylinder
Clutchmasters Stage3 clutch
BJ's lightened and cryogenically frozen flywheel
B&M short throw shifter
MOMO shift ****
Symborski shift kit
Roller shift cables
Kazera 17" wheels
Yokohama ES100 225/45-17ZR
Cooling
New all metal radiator
New radiator hoses
Electronics/Accessories
GReddy turbo timer
Ball-and-spring manual boost controller
A-pillar gauge pod
Autometer Phantom EGT gauge
Autometer Phantom boost gauge
Clear side markers
Picture Link
Chuck
Head
1G head
3-angle valve job
ARP head studs
HKS cams 264/264
2G revised lifters
Block
New oil pump cover
New oil pump
New water pump
Intake manifold
1G Intake Manifold
Exhaust
Ported 16G turbo
SS oil line
Intake
3” intake with K&N
Fuel
Fuel pump rewire
Ignition
SS clutch line
MOMO shift ****
Symborski shift kit
Roller shift cables
Kazera 17" wheels
Cooling
New radiator hoses
GReddy turbo timer
A-pillar gauge pod
Clear side markers
Re: F/S: 1995 Eagle Talon TSi AWD
Originally Posted by Omega
autoxr166
Sep 25, 2015 04:21 PM
