94' Rear-end re-build, am i missing anything?
Old Jan 22, 2005 | 04:33 PM
AmericanMuscle33's Avatar
Question 94' Rear-end re-build, am i missing anything?
Ok, so my car has near 150,000 miles one 'er, and the stock diff is definately tired, 1 wheel peel on slick surfaces is its new habit. Also it sounds like a jet flying by with all the rear-end noise. So, my plan is to put in an Eaton posi 3-series carrier (already purchased), 4.10 gears, and while i'm at it, have new HD u-joints put on while the driveshaft gets balanced. My question is what all should I expect to buy to complete this. Some people say re-use the bearings on the pinon...is this a good idea? Or should I plan to replace all bearings with new. I'm told i can buy a shim kit for relatively cheap, so i'll prolly do that locally. I'm going to purchase a Hypertech programmer to take care of the ecu, so the A4 cooperates, and other than that I'd just like to know if I have my bases covered. Thanks,
Old Jan 23, 2005 | 01:25 AM
Pro Built Automatics's Avatar
Re: 94' Rear-end re-build, am i missing anything?
Always use an "install kit". Lucas 85-140w is a good oil, along with the GM posi additive.
Old Jan 24, 2005 | 12:15 PM
I'm planning on using all BG fluids. Do you guys recommend buying the Master Install kits that come with all bearings, shims, gaskets, etc. or would a basic install kit suffice?
Old Jan 25, 2005 | 02:20 PM
Get the install kit with everything needed. BG fluid?
Old Jan 25, 2005 | 07:41 PM
I'll get the full bearing kit. Yeah, BG they make some pretty high quality fluids...My brother's a Tech at a GM dealership here, and recently a BG rep came buy, now they are a distributor for them. Its pretty spendy crap, upwards of $20+ a quart depending on what you buy. But he gets cut "special" deals, and he has a couple 15 gallon drums of Gear Oil, also a wide assortment of Tranny Flushes, Coolant Flushes, each like 50 bucks per lil can i think, but it'd be all free to me, so I figure why not.
Old Jan 25, 2005 | 09:36 PM
OBE1 95Z28's Avatar
4.10 gears with an A4...I guess you like high rpms
Old Jan 26, 2005 | 02:08 AM
GreenDemon's Avatar
I certainly didn't live in back then but I've heard stories about big blocks with 3.73s and turbo 400s... I don't know how they did it- I suppose 60 was the fastest anybody cruised around then though.
Old Jan 26, 2005 | 12:35 PM
Yeah, the car almost never sees freeway...cruising rpms are not an issue for me.
Old Jan 27, 2005 | 03:01 PM
OBE1 95Z28's Avatar
I think traction will be non-existent in first gear with that gear ratio. My friend's got 3.42's in his A4 and he can barely get it to hook on the street. If it's a track only car, that's a different story.
Old Jan 27, 2005 | 03:17 PM
its not a track only car, but lack of traction doesn't bother me...I've been planning on this setup for a while now...
93 RedBird
Nov 15, 2015 08:24 AM
Z28ELECTRICIAN
Oct 19, 2015 06:36 AM
Bigfatrat
Parts Wanted
Oct 4, 2015 08:54 PM
Ks0209
Oct 1, 2015 07:32 AM
tommalcolm
Sep 11, 2015 03:39 PM
