Grinding in front end somewhere, im lost. HELP
Old Jan 17, 2005 | 05:15 PM
78sixbanger's Avatar
ok, What could cause a rubbing/grinding from under my car in the front. It only happens when im goin around 60+mph and turn my wheel right. Just had my Rack and pinion replaced. I have no clue what it could be. I snapped my rear axle about a month ago and that is when it started. I hit black ice, spun out, and slammed into a curb. Any ideas would be greatly appreciated. thank you.
Old Jan 18, 2005 | 08:17 AM
Re: Grinding in front end somewhere, im lost. HELP
ttt, anyone?
Old Jan 18, 2005 | 09:16 AM
shouldaboughtthez's Avatar
Have you jacked the car up and turn the wheels to the right and start spinning them? Try to recreate the problem.
Old Jan 18, 2005 | 10:34 AM
yeah, i cant see anything wrong under there, and it only happens at speeds of 50+.
Old Jan 18, 2005 | 11:27 AM
moparman's Avatar
Bearing?
Old Jan 18, 2005 | 12:14 PM
Wouldnt a bad bearing be grinding all the time? My alignment is off a little, it was suposed to be aligned last week when I had them try to fix the problem and they replaced the rack. Whether they did it or not idk, but the car is def out of alignment again.
Old Jan 18, 2005 | 12:39 PM
IRONFIST's Avatar
That is a bad bearing... I know, because I had the exact same problem. The reason it's only happening when you are going fast and turning right is because that is when you are loading up your left wheel.
Old Jan 18, 2005 | 01:12 PM
Kataklysm's Avatar
Change the wheel hubs. My old grand am did the same type of sound.
Old Jan 18, 2005 | 02:45 PM
Thanks guys, gonna pick up 2 new bearings tonight
PublicEnemy1
Apr 7, 2015 12:21 PM
8T8IROC
Mar 26, 2015 09:02 PM
karguy16
Mar 6, 2015 01:33 AM
willie-d-nice
Feb 13, 2015 06:40 AM
