badapple
01-15-2005, 08:21 PM
One owner, In Service Date: 03/15/22
Excellent condition, 9,400 miles
Sunset Orange Metallic, w/black roof panel
Stored 6 months each year(Oct.-Apr.).
Factory Installed Options
16" Chromed aluminum 10 spoke wheels
Goodyear P245/50 ZR-16 radial b/w tires
Leather wrapped steering wheel w/radio controls
Rear window defogger
Performance Modifications
Nitrous Express #20920 50-150 adjustable h.p. system w/purge vave, fuel pressure safety switch, N2O pressure gauge, bottle heater, N2O filter, & fuel line pressure gauge.
MSD rpm activated window switch, w/rpm modules.
SLP lid w/K&N filter kit
SLP smooth bellows
SlP 160* thermostat
SLP line lock
SLP large diameter s/steel y-pipe
SLP loud mouth cat-back exhaust (s/steel w/slash-cut tips)
SLP strut tower brace
SLP sub-fame connectors
SLP driveshaft loop
SLP skip-shift eliminator
SLP leather shift handle
Speed Inc. throttle body by-pass
Spec stage 3 ceramic clutch kit(550 miles)
Spec steel billet flywheel
B&M super ripper shifter
Performance Suspension urethane transmission mount
BMR adjustable panhard rod
Thunder Racing lower control arms
Moser 12 bolt rear w/4:30 pro street gears, Eaton 33 spline posi, billet end caps, 33 spline axles, long length studs, large U-joints.
Moser billet aluminum cover w/adjustable cap studs
Harlan programmable shift light(mounted in pillar post)
DiabloSport Predator pcm tuner/scanner w/custom tune for N2O included
NEC Pentium 2/433mhz laptop computer(for Predator tuning)
Rear floor mounted fire extinguisher
Ram air modification to airbox completed
Throttle body by-pass modification completed
Mickey Thompson ET Street tires 10.5 x 16 mounted & balanced on 9" Chevrolet 10 spoke aluminum Camaro rims
Factory cat-back exhaust approx. 1,000 miles(included)
Factory clutch w/flywheel w/approx, 9,000 miles(included)
Technical and installation manuals, receipts ec.(included)
$18,000
413-594-4888(home)
413-977-3096(cell)
SLP smooth bellows
SlP 160* thermostat
SLP line lock
SLP driveshaft loop
$18,000
413-594-4888(home)
413-977-3096(cell)
