Ewan Glendinning
01-11-2005, 03:28 PM
1981 malibu
car was originally white, flat black now
has fiberglass t&n hood
454 fender badges
all bodywork done
brand new window (all glas is good)
has burgendey interior
buckets and consol
b&n ratchet shifter
white face oil pressure, water, and batt gauge
white face Autometer Phantom 5 tach and shiftlight and 160mph speedo
has only stock deck
Holley blue electric fuel pump and regulator set to 7psi
All aluminum race lines and braided
Driveshaft hoop
All susp is good
rear and front sway bars
The diff
7.5
Auburn pro posi
3.73:1 gm gears
mosier 28 spline axels
new bearings
the trans
turbo 350
b and m stage two
fresh rebuild
10" 3800 pro west stall
aftermarket trans cooler.
the motor
low km 454cu (Pass high perf block) originally had forged pistons but probably not after the rebuild.
new cam/ lifters
new timing chain
oval part heads
edlebrock intake
holley 750double pumper
14" K&n intake
chrome valvecovers
brand new waterpump
hooker 2242 big block
headders
msd 8.5mm wires (fiberglass boot covers)
msd pro billet dist
msd blaster 2 coil
msd 6a box
brand new mini starter
has the better pushrods
cooling
3 core rad
2 honda civic electric fans
comes with four stock malibu wheels
also comes with 2 15x26x11.5 mickey thompson et streets
car needs paint and rims I guess
And to be a driver needs mid pipes between the headder collectors and the mufflers. Or you could try to make the current 3 " exhaust work The crossmember is already notched for duals and the mufflers are 3" dominators (i think) they sound bretty good and flow realy well
Other things the car needs headliner finished and the seats bolted in completely. and some other misc stuff
I have owned this car for 2.5 years and am now planning a new project
It isnt a rebuild and I know of no previous damage the body has no rust or bondo, and the frame is MINT!!!!!!!!!!
I aint going to bs about the price I want $6000 firm and I would sooner slit my wrists in the bathtub than sell it for a penny less!
I got a stack of reciepts which rivals the phone book for thickness.
If you want a car capable of cookin the tires anywhere any time this is it
Priced to sell
call Ewan 604 853 8926
car is in Abbottsford will not ship!
will post more when I think of it
454 fender badges
all bodywork done
buckets and consol
b&n ratchet shifter
has only stock deck
Driveshaft hoop
All susp is good
The diff
7.5
Auburn pro posi
3.73:1 gm gears
new bearings
the trans
turbo 350
b and m stage two
fresh rebuild
the motor
new cam/ lifters
new timing chain
oval part heads
edlebrock intake
14" K&n intake
chrome valvecovers
brand new waterpump
headders
msd pro billet dist
msd blaster 2 coil
msd 6a box
cooling
3 core rad
Priced to sell
