Fuel line questions
Old Jan 9, 2005 | 12:15 PM
jcstew02's Avatar
Fuel line questions
Im wondering if my fuel line is big enough. I have a SBC heavily built stroker with a 800 holley. It also has a NOS sportsman fogger jetted for about 300 HP. Im feeding all this with a holley electric fuel pump through a 3/8 fuel line. So my question is what size fuel line is everybody else running? Do you think 3/8 is large enough? I just put all this together only sprayed it once in 3rd gear for a second as a test.
Old Jan 9, 2005 | 01:43 PM
IRONFIST's Avatar
Re: Fuel line questions
When in doubt, go bigger... especially with nitrous.
Old Jan 9, 2005 | 05:35 PM
captaindbol's Avatar
Your setup is plenty for the engine side of things. I would consider a secondary fuel system for the nitrous or swaping to a efi style fuel pump with a return style regulator though.
Old Jan 10, 2005 | 10:04 AM
jcstew02's Avatar
I have regulators and Pressure gauges on both the carb and the nitrous. Im just a little concerned about getting lean at WOT while spraying.... Is anyone on here running a simalar setup?
Old Jan 10, 2005 | 10:16 AM
What pump are you running? Reason for asking is I don't trust a deadhead style system to provide that much fuel. If you are going to go that route anyway, step up to a b/g or magnaflow style pump and run a 10an line to the front with a y-block to your current regulators. BTW, I currently run a Paxton1100(same as the aeromotive A1000) with a mallory bypass regulator(10an feed, 8an return) for the engine side of things.(504fwhp) And a 1gallon fuel cell with a Holley black pump and deadhead regulator for a 225hp plate system.
Old Jan 10, 2005 | 12:35 PM
jcstew02's Avatar
-10AN thats 1/2 " isnt it? My pump is a holley electric pump.. I cant remember the model # but its huge. I have it run through a filter to the front of the car to a Y block one side For the nitrous regulator the other to the carb regulator. But if your running all that through one -10an that makes me feel alot better.
Old Jan 10, 2005 | 01:36 PM
Damon's Avatar
I would think a single 1/2 line would be minimum. I run 3/8" line up to 550HP without any pressure drop-off, but if you're up in the 700+ range, then I would be very nervous about a single 3/8" line.
It's not the steady-state demand that gets you. It's the hard acceleration through the lower gears. You can keep up with fuel demands on a stationary dyno without anything special as far as the fuel system goes, but when you get it in the car and have to deal with the hard acceleration that a 700+ HP engine can generate that's when you start outrunning the fuel system.
As was suggested, above, it would probably be a very good idea to run a completely separate fuel system for the nitrous.
Old Jan 10, 2005 | 03:10 PM
jcstew02's Avatar
I had thought about that before(secondary fuel system). I was just curious what everyone else was doing. I have everything but the pump, so I guess I will buy another pump and just run another fuel line. I may use the existing 3/8 for Nitrous and use 1/2 for carb.
Thanks for the help!
Old Jan 11, 2005 | 01:35 PM
Z28SORR's Avatar
A -10AN line is a reference to the outside diam. So depending on the line type you will probably have some where between 1/2" to 9/16" inside diam.
These are giving in 1/16th of an inch. So a -10 is 10/16" or 5/8", a -4 would be 4/16" or 1/4" O.D.
HectorM52
Jul 30, 2017 11:46 AM
Deadbolt24
Jan 19, 2015 01:29 PM
squarehead
Nov 21, 2014 08:02 PM
Jul 4, 2005 05:00 PM
