Is this the right pin to wire the MSD window switch
91RSLT1
01-09-2005, 11:14 AM
The motor is a 95 and from looking at the wiring diagram I need to tie into the red connector pin A13 tach output (white) and tie it into the window switch's white wire. Is this correct? I also have a MSD dig. 6 and was wondering if it has a tach output I can tie into instead of using the pin out of the PCM (I can't find my owners manual). Thanks
92LT1RS
01-10-2005, 11:52 PM
My MSD 6AL has a tach output, I'm sure the 6 Digital does too.
91RSLT1
01-11-2005, 11:55 AM
Thanks I just found my manual and the dig 6 does have a tach out put so I will just use that.
