96 Formula needs a little work and sweet 355 street motor FS
gearheads78
01-07-2005, 01:22 AM
No time and too many projects tells me I need to clean up around the house.
96 Black HT cloth Formula M6 need front bumper cover painted. Body was never wrecked and is in good shape. It does have the typicle door dings in th e 1/4s It has Apox 85K on body. I drove it for a while with the worn out motor and everything worked great except the power streering sometimes didn't work. Car has V6 wheels and tail lights because I was going to build it as a sleeper for my wife to drive.
The nose is currently off the car so my engine host will reach. Motor was worn out. I have a 94 Motor w 77K out of a totaled car ready to drop in. Its all converted
to 96 opti and cam and such.
- new water pump GM
- new GM opti
- all new gaskets
- new GM plugs and wires
- new clutch pressure plate
- new timming chain
- new driver side window motor
This is a car that in a couple of weekends you would have a awsome driver.
I will deliver for free up to aprox 100 mile radius of Dallas
3000.00
LT1 355 new long block built as a killer street motor for a daily driver / weekend warrior. I spent a ton of money on this thing with plans to put it in the car above. All parts are brand new.
- assembly and machine work by Watts racing engines
- comp cc305 cam
- hardend push rods
- Comp roller rockers self aligning
- cloyes chain
- JE pistons
- total seal rings (gapped for 150 or less NOS)
- bored and honed with torque plates
- fully balanced
- stock rods with ARP bolts
- Stock 1.94 valve heads ported by Trevor Johnson Racing Heads with intake ported to match (flow 252/196 @.500)
Probably more I am forgetting
3200.00 Firm
Richard 214-793-0029
