greatwhitez
01-05-2005, 05:12 PM
Hello guys,
I would greatly apreciate your help, i'm looking to put a "serious" kit on my car. i mean serious like either under the intake manifold or possibley some other way? Me being rather new to the n20 world would like some advice and guidance if possible from some of you guys who are really experienced in this field.
my car is a 95 lt1 M6, 12-bolt, spec clutch, full suspension. etc..
the motor is a lt1 block bored/stroked to a 396 splayed 4bolt. FORGED Eagle 4340 crank,forged h-beam rods, SRP forged aluminum pistons, approx 12:1 comp.
valvetrain: gm 847 cam, comp r lifters, 1.6 pro mags, chromoly push rods, 2.00/1.56 manley valves, k-800 springs w/ ti retainers. all installed in fully ported up lt1 heads, flow approx 270 @ .600 on the intake side.
intake is port matched, 58mm tb, 255 walbro intank pump, lucas 42lb hr injectors.
I would like to know what you guys reccomend that i will need to spray around 200-300 shot at it. I want to keep it running safely no chances, but i need to know what is a good kit to put out this kind of shot, and also what i will need along w/ this.
thanks in advance,
Nick
thanks in advance,
Nick
