Removing Bird dropping off the hood
I justed walked out to my car and notice there was some bird dropping on my hood. I used some care cleaner soap and washed off whatever I can. It seemed like everything was off until I notice that it left marks on the hood. I used a clay bar but it did only a little. What can I use to take that mark off???
Re: Removing Bird dropping off the hood
Same thing happned to the hood of my brother's Firehawk
I used '3M's 'Finesse-It' for dark colored cars, and followed it up with another coat of Zaino. It removed the mark on his hood
I've also experienced marks that DIDN'T come out using this method, (after droppings sat for waay too long), and I had the clear coat wet sanded at the body shop and it the paint looked 100% better.
Bird Bombs
A bird’s droppings are very acidic (pH 3.5 to 4.5). When bird droppings fall on your paint, the acid begins to burn and etch the paint’s surface. The longer the bird droppings remain, the greater the damage.
The result of bird dropping damage is a dimple in the paint’s surface, often as large as an inch or more in diameter. This damage is permanent, but can easily be repaired.
Repairing Damage
The only way to repair the damage caused by bird droppings is to polish the paint. You must use the polish to blending the surrounding paint, bringing it down to the same level as the damaged area. This may sound drastic, but it works very well. The only concern is that you’re making the paint thinner. So you must be careful not to polish all the way through to the primer. Do so, and you’ll have a more noticeable problem than what the bird left behind.
Any good paint polish can be used to fix the damage with a fair amount of rubbing. I’ve found that it’s better to start with a mild compound, as you would find in a “scratch remover” (Eagle One Scratch Remover is a good example), followed by a good hand polish.
Preventing Damage
While it’s not really possible to keep birds from bombing your car with their dirty little surprises, you can take steps to limit the damage. The most obvious protection is a car cover (please, not while you’re driving). But, even the cover won’t help you when you’re driving. To limit the damage when you get hit, you need to remove the offending slim as quickly as possible. Don’t wait. Get it off of your car.
I’ve found the best way to clean up after a bird is with a good detailing spray and a cotton terry cloth towel. As I’m a clean car fanatic anyway, I keep a little detailing kit in my trunk. It holds a spray bottle of quick detailing spray, a couple towels, and my favorite rubber and vinyl dressing. That’s all it takes for me to keep the car looking great. When a bird gets me, I spray the bird droppings with a few shots of detailing spray and wipe it off with the towel, turning the towel as necessary to keep a clean wipe on the car.
Another way to protect your paint from bird damage is to keep your car waxed. While a standard carnauba wax offers limited protection against a juicy attack, it makes cleanup much easier. Acrylic polymer sealants protect a little better against the harsh acids, but it’s not enough to create a damage-free barrier if the bird poop sits too long. You still need to remove the mess as quickly as possible.
Repairing Damage
Preventing Damage
i would wash and clay and then use a contaminant cleaner or mild abrasive polish and then a wax.
for future reference, if you notice a "poop" that might be "fresh" then, get a soft paper towel andlay it over the "damage spot" and then poor white vinegar on the towel, give it a few mintues to soak and then wipe clean.
the vinegar helps loosen the "load"
yea i just got one on my car yesterday. I also had my hood painted last week so it doesnt have any wax on it....unless the body shop put some on. wiped it off and it ate into the paint a bit. Im pretty pissed but I am gonna try and polish it out. GGRRRRRR
I do WHATEVER it takes to get the poo off as soon as I find it. I've spit on my car before and used a McDonald's napkin out of the glove box. The rest can be cleaned up when you get home. Don't EVER let bird poo sit on paint.
thanks for the info guys. i recently had her repainted completely. they didnt wet sand it yet so i will take it back next week and then i will post some pics up on the new paint job. same color just more shiny black
Oncomingstorm22
Jan 22, 2015 07:15 PM
CARiD
Jan 14, 2015 04:00 AM
