Firebird Headlight Problem
Old Jan 4, 2005 | 05:50 PM
95 firechicken's Avatar
My headlights decided not to go down yesterday morning so I figured I blew a fuse but when I came out of work they were both down???? now they won't go up so I figured the switch went bad so I replaced now the passenger light goes up and down fine but the drivers side doesn't even try to move could this be the control module??
Old Jan 4, 2005 | 10:07 PM
Re: Firebird Headlight Problem
Ttt
Old Jan 5, 2005 | 07:46 AM
1SlowFormula's Avatar
Mine did this a while back before the gear in the headlight motor broke. To get it to work right have them switched off, then pop the hood and manually crank the one that doesn't go up a few times clockwise then back counterclockwise, trying to make it sense being down, and then try to put them up with the switch. I think there a sensor in there and it doesn't know it is down so it doesn't try to lift it, this happens when the nylon gear in the motor starts to strip out but hasn't fully stopped working. Sorry if that ran on without making sense if you don't understand what I was saying ask and I will try to clear it up. This is all conjecture and not sure why it work I just know that this is how I got mine to work, but about a week or 2 later the nylon gear was totally stripped and needed to be flipped. Check Brent Franker's site for the instruction on flipping the gear.
Old Jan 5, 2005 | 07:57 AM
I tried the free headlight fix before i posted sorry i should have put that in the first post
Old Jan 5, 2005 | 03:51 PM
Black_95Formula's Avatar
I had the same problem. The best fix is to replace the crappy nylon gear with a nice brass piece (search google for it -- or maybe Brent has the link on his site). It was not expensive and should fix the problem. Good luck!
Old Jan 5, 2005 | 05:32 PM
Brent94Z's Avatar
Super Moderator
I've got a TON of info I'll be sticking on my site about these headlights. Here is a sneak preview for you that you may find helpful
4) The headlight just won't go up at all and it seems like the motor is shot. This could actually be a couple of things. The easiest thing and is actually quite common is that the headlight motor connector gets very corroded. There ends up being so much corrosion in there that 12v can no longer make it through the corrosion to the headlight motor and it just quits working. Unplug the connector near the headlight motor and check the connections. Normally it will be very easy for you to see this corrosion as the connector may even appear burned or slightly melted due to the heat caused by the high resistance just prior to it completely not working. This is an easy check and is free so look at this first if your light doesn't move at all.
5) The headlight won't go up or once up, the headlight will not lower. If it is not the corroded connector like mentioned above then it could be the light is getting jammed in place. This can happen with either the nylon or brass gears. I'm not 100% certain what causes it but it does seem to be related to some moving part in the headlight assembly wearing. Believe it or not, I don't actually have a Firebird anymore so can't study this and figure out exactly why It does seem to happen primarily on older Firebirds or ones where the lights get a lot of use so I do believe it is caused by something wearing which causes the light to get jammed in place. A lot of people will just raise the hood, spin the manual raise/lower **** a couple times, and then the light will go up/down. This fixes the problem but only for that one cycle and that is no good. The good news though is that I can explain a fix to ya that seems to work most of the time. What you can do to help prevent the light from getting jammed is to STOP it a little early. This will help to prevent the light from getting jammed. You can do this by making the stops which the raise/lower arm make contact with a little larger. Since they are molded into the plastic front headlight frame, just putting a larger one on isn't an option. But, what you can do is something fairly simple. It might require a little trial and error but the fix will be easy and cheap. What you need to do is put some THICK and fairly firm rubber tubing/hose over the stop. The tubing/hose has to have an inside diameter such that it will fit snugly on the existing stop or it will fall off What this will do is make the raise/lower arm make contact SOONER which means that the light will not go up (or down) quite as far and thus, hopefully, prevent it from getting jammed in place. If you try this and find that it didn't work for you, it is possible your tubing/hose is too soft or not thick enough. If too soft, get a harder hose If not thick enough you can either replace it with a thicker piece of tubing/hose or you can add ANOTHER piece of tubing/hose over the existing one to make it thicker which will stop the light even sooner. I don't know what size is best for this. There are so many brands and sizes out there that it would be impossible for me to list what works. What you can do though is take a look down in there and locate these stops. Use a pencil or bolt or whatever you have that is about the same size. You can then go to Home Depot or a hardware store and go to the tubing/hose section and get a few pieces like 6" or 1' long or however short they'll allow you to purchase. You should be able to get several sizes and hunks to experiment with for just a buck or two and have more than enough to do both your lights.
5a) On a side note and kinda related to problem 5 above is that you may find that you experienced the light getting jammed. Knowing that these lights have a raise/lower **** associated with them, you used the raise/lower **** to get the light started and then cycled them electrically and they worked. However, right after you did this when the light went down, you heard the terrible noise of a stripped gear. Bummer. What I believe happens and I've heard of it a couple of times is that what happened is some teeth on the nylon gear actually BROKE and that is what caused the light to jam in place. Then, after the next cycle of the light the stripped gear with the broken teeth became obvious by the grinding noise.
ChrisFrez
Feb 15, 2015 08:12 AM
Brake_L8
Jan 20, 2015 09:44 AM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
CaRParts102
Dec 6, 2014 08:45 AM
