Shifter moves up and down
97LT1F-Body
01-01-2005, 09:27 PM
I cant figure out why my shifter moves up and down when Im taking off from 1st to 2nd under normal driving. :confused: It just started doing this within the past few days and is really annoying.
I replaced the tranny mount and I took the shifter out to make sure the bushing wasnt broke. Im still having the problem after I did these two.
Any suggestions would be great.
Thanks.
Mike
mc63
01-02-2005, 10:52 AM
Sounds to me like you have a broken motor mount. Check the drivers side.
blown94
01-02-2005, 11:46 AM
ditto, you gotta have a broken mount
97LT1F-Body
01-02-2005, 12:50 PM
Thanks guys. I will check this out right away.
Mike
97LT1F-Body
01-02-2005, 06:20 PM
well, no luck yet, I still havent been able to pin point the problem. I checked both motor mounts and both are okay. Anyone else that may have a clue, your suggestions would be much appreciated.
Mike
blown94
01-06-2005, 01:52 AM
You replaced the trans mount already? Thats usually the culprit of this problem, I had one that was torn in 2 and smacking the floor on hard accel. Check it again anyways, not to sound sarcastic or anything, maybe you lost your nut (lol)
