What oil are you all using on your blower cars?
CoUnTryMuZiCZ28
12-31-2004, 10:17 PM
Im just wondering because I was going over the manual and vortech calls for 20W 50 oil.. Im using regular 10W 30 oil.. The motor is a brand new 383. I didnt want to go that thick since everything is pretty tight in there and thicker oil I always thought was to make up for wear. I was thinking of going to a 15W 50 mobil 1 synthetic oil but im not sure if I should go that think on my 383. Then I was thinking of the oil break down and the added heat on the oil because of the charger. that being another reason I want to go thicker.. Also my blower is extremly loud. I was thinking the oil maybe the culprit.
Thanks!
Happy new year too..
Nick
RCF925
01-01-2005, 12:25 AM
If you have a new 383 I would use what the engine builder recommends. If you built it with stock clearances then you'll be fine with 10-30 Synthetic after break-in. I have a Vortech and I run Mobil 1 10-30 in the winter and 15-50 in the summer.
CoUnTryMuZiCZ28
01-01-2005, 03:51 PM
Im in FL... its like summer all year.. mostly humid if anything though.
Lisa33
01-01-2005, 07:16 PM
Castrol RS 10-60 in the summer, dont drive it in the winter season.
Pro Stock John
01-03-2005, 12:58 PM
10w40
SDAKOVIC
01-03-2005, 08:52 PM
10w40 stored in winters.
CoUnTryMuZiCZ28
01-04-2005, 12:30 AM
switched to castrol GTX 10 40.. was using castrol GTX 10 30.. seems to run a bit smoother.
ATMINF
01-06-2005, 12:36 AM
0-40 Mobil syth euro car formula.
