Brake light problem, need help!
PonyStalkerZ28
12-31-2004, 03:01 AM
I am having problems with my brake lights and was wondering if anyone could help. My problem is that my SS spoiler is the only one that DOES work, the tailights dont. At first I thought brakelight switch but then thought it couldnt be that if the spoiler brakelight works, cause none should work if it was the switch. Could it be the switch, or something else? :confused: Any help is greatly appreciated. :bow:
Brenden
elguapo
12-31-2004, 12:45 PM
Bulbs? Is the light on the spoiler wired to the tailights? If not I would check for a short on the taillights.
PonyStalkerZ28
01-01-2005, 05:14 PM
yeah I replaced the bulbs, and I am pretty sure the tailights are wired with the spoiler also.
1BAD80-Z
01-01-2005, 08:56 PM
The brake lights go through the turn signal switch , the easiest way to check it without five pages of electrical diagnostics , is to buy or borrow a t-signal switch and plug it in under the dash and see if it works then , if so , then you've found the problem !! ( it's usually the culprit ) :) :)
ElkyRacer
01-02-2005, 02:32 AM
Theres a thin long connector under the steering column, its about 3-4 inches wide. Thats some of the brake lite connectors, it sometimes rattles loose a bit. Try plugging it up some more I had to take a zip tie and tie around it to make sure it wouldnt rattle loose again.
Kyle
PonyStalkerZ28
01-03-2005, 07:22 PM
Thanks guys, I appreciate the help. I will check those things out.
PonyStalkerZ28
01-08-2005, 01:10 AM
Kyle
I messed with a black connector that was about that wide and like a half inch thick and it fixed the problem.
Thanks guys for the help. :bow: :cz28:
Brenden
ElkyRacer
01-08-2005, 06:59 PM
No prob. Glad you found it.
Kyle
