b55baron
12-29-2004, 11:19 AM
I would like to get the GM part numbers for the 1LE front and rear sway bars that would fit my 2000 Z/28. I believe they are 32mm front and 21mm rear.
Thanks for the help.
GM part numbers 1LE sway barsb55baron 12-29-2004, 11:19 AM I would like to get the GM part numbers for the 1LE front and rear sway bars that would fit my 2000 Z/28. I believe they are 32mm front and 21mm rear. Thanks for the help. OBE1 95Z28 12-29-2004, 02:36 PM Before buying these parts, talk with Sam Strano at stranoparts.com. He's a F-Body suspension expert and can help you setup your handling. b55baron 01-07-2005, 12:54 PM Before buying these parts, talk with Sam Strano at stranoparts.com. He's a F-Body suspension expert and can help you setup your handling. I talked to Sam yesterday. He was extremely generous with both his time and his expertise. I ordered the sway bar kit that is made for him by Addco. I will be going back to him for more suspension parts as $$$ allows. Thanks for the tip. | ||
