help?!!! no brakes
jz3082
12-28-2004, 05:02 PM
I did the ls1 brake upgrade on my 94 and that was pretty simple but for some reason the brakes won't bleed correctly. No matter how many times i bleed them and the hydraulic modulator they are still squishy and barely work. Anyone have any ideas. THanks.
-Jeff
camaroz28_97
12-28-2004, 09:22 PM
how did you blead them?? their is probably still air in the line.
94blackz14.2
12-28-2004, 09:51 PM
Did you put the calipers on the correct sides. My friend and I ran into the same problem on another veichle and it ended up that we had them on the wrong sides causing the bleeder to be on the bottom side of the caliper instead of the top. We bleed and bleed till we couldn't blead anymore and then figured out our mistake. Just something to look for.
jz3082
12-29-2004, 12:35 AM
they are on the correct sides and i bleed the modulator then the rear and fronts in order and still air in there. How would i get it out?
