M6 will not go into gear while car is running
Old Dec 28, 2004 | 10:32 AM
Guggi97_RA's Avatar
I was driving home yesterday and I noticed that I was all of a sudden having a hard time getting the car into gear. Pretty soon I had to really force it into the gears in order to get home.
Wih the engine off, I can place the tranny in any gear without issue. When I start the car, I can leave it running with the clutch pressed in and the tranny in 1st... Trying to get it out of gear when it is running is just as hard.
I suspect the throw out bearing? Anyone concur? What about the pilot bearing?
Its a mcleod clutch. Is the throw out bearing replaceable, or do I need to replace the whole pressure plate assembly?
Adam G
Old Dec 28, 2004 | 12:54 PM
OBE1 95Z28's Avatar
Re: M6 will not go into gear while car is running
A faulty pressure plate will cause your issue.
Old Dec 29, 2004 | 08:42 PM
Guggi97_RA's Avatar
Oddly enough, I fiddled with the car in the driveway, and now I am able to get it into gear without issue, and it drives normal. I'm not sure what the deal was, and I am not sure if I should trust it ? Any ideas on what may have caused the temporary issue? Is it a sign of certain failure soon to come? Maybe a chunk of something loose in there?
Adam G
97SSdude
Dec 31, 2014 07:43 PM
ChrisFrez
Dec 21, 2014 09:47 PM
ChrisFrez
Dec 15, 2014 03:09 PM
nophix
Nov 30, 2014 10:26 PM
USAirman93
Nov 24, 2014 03:37 PM
