Dave93Z
12-26-2004, 03:16 PM
What kind of maximum timing advance is typical for a stock LT1 with 6-7 PSI of intercooled boost?
Stock 96 Impala SS LT1 engine
P-1SC ProCharger
28-29 degrees at WOT
I move about 370 GPS of air by the time it shifts around 5500 RPM.
OBD-I PCM (converted to use the OBD-II knock sensors)
LT4 Knock Module already installed
93 octane
I'm getting frequent knock counts and resulting KR that goes away if I pull a good amount of timing with my BTM. If I'm should be running a lot less WOT timing than I currently am, great.. I'll just have it tuned accordingly. If I should be able to run 28-29 degrees of timing at WOT, I need to figure out
If I run the full timing the car hauls. Naturally, with the BTM pulling lots of timing the car isn't quite as quick as far as my butt-o-meter is concerned. :D
Just wondering how much timing (without any resulting KR) people have known to be able to run on a stock LT1 with 93 octance and a similar 6-7 PSI of maximum boost.
Thanks Dave
P-1SC ProCharger
93 octane
Thanks Dave
