Qa1 help
AlmostfastLT1
12-22-2004, 04:14 PM
I have the QA1 generation F shock and coilover. I am installing it on my 94z LT1. My question is what is the torque spec for the nut on that you tighten the bump stop down on the spring. Has anyone installed these???
Torquing the nut to spec should keep the spring from rotating on the washer adn spring seat, etc.
Thanks, need help fast!
AlmostfastLT1
12-22-2004, 04:23 PM
Also, what are the torque specs on the upper control arm, and the bolts on the strut tower.
AlmostfastLT1
12-24-2004, 06:31 PM
Also, do I need the bumpstops off the old stock de carbons shock????
