Toms30th
12-22-2004, 02:54 PM
I'm going to be buying a TPI thrid gen in the next couple of months and I would like to supercharge it. Is it possible to run boost on a stock daily driver? At what boost level should I build the bottom end?
Can You Supercharge a Stock 3rd Gen?Toms30th 12-22-2004, 02:54 PM I'm going to be buying a TPI thrid gen in the next couple of months and I would like to supercharge it. Is it possible to run boost on a stock daily driver? At what boost level should I build the bottom end? KS91Z28 12-22-2004, 11:03 PM It depends on how many miles the engine has on it. I supercharged my stock 3rd gen, and have been driving it back and forth to work for 3 years now. If you want to go over 8 or 9 psi intercooled, then you will need to start modifying your engine. | ||
