Can't get my driveshaft disconected
Old Dec 20, 2004 | 12:16 PM
YZF/LS1 Freak's Avatar
I am trying to do a rear end swap and the only things left are the shocks, LCA's, brake line over the rear, and the driveshaft. I removed the two c shaped clamp things that connect the shaft to the rear end and it looks like the shaft has to slide forward for the shaft to drop out but it will not move at all in any direction. Am I missing something or just not using enough elbow grease?
It was taken out about 8k miles ago for a tranny rebuild and its the stock peice.
Old Dec 20, 2004 | 01:15 PM
87DJP2001's Avatar
Re: Can't get my driveshaft disconected
Did you remove the (4) bolts from the rear end yoke to drop the shaft from the rear????
Old Dec 20, 2004 | 01:27 PM
97FormulaWS-6's Avatar
Large Flat-head screwdriver... pry it right out of there....
Old Dec 20, 2004 | 01:54 PM
2001NBMZ28's Avatar
Yeah, just needs to move forward a little - nothing else holding it in.
Old Dec 20, 2004 | 02:00 PM
87DJP2001's Avatar
Then its hanging up in the tranny, its just spline to spline and needs to broken free. Itis a tight fit with the splines and seal.
Old Dec 20, 2004 | 02:39 PM
hotrod18_69's Avatar
Works for me everytime!!
Old Dec 20, 2004 | 09:08 PM
Ok I will try the flat head,
Thanks guys.
Oh by the way, I am doing the swap with the car having 110k miles and no air tools, I will never ever do that again.....
RUENUF
Mar 13, 2016 03:37 PM
Henson071
Dec 30, 2015 09:55 PM
ryanhilsgen
9
Sep 21, 2015 07:34 PM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
realistyc
Jul 28, 2015 07:32 PM
