Traction
Ripcurl3249
12-19-2004, 12:30 PM
I have a 96Z. My 60' times around 2.2 with 3.73 gears and 315 tires in the rear. Wat are some other things I can do so I get better traction.
Severous01
12-19-2004, 12:52 PM
spend the 700 on phr, lca, and torque arm...then buy stickeys...you should be in the 1.9-1.8 with that. surprisingly i had a 1.9 with all factory. was this with a corrected time or not?
revtime
12-19-2004, 11:43 PM
Some sticky tires will make the biggest difference.
I have an Eibach drag launch kit and LCAs, PHR, BMR relo brackets and an adjustable TA and along with 275 Nitto drag radials it solved my traction problems.
Start with the LCAs and then the relocation brackets, they helped the most on my car.
