front sway bar removal
Jameslt1TA
12-18-2004, 10:09 PM
hey guys i got a quick question... how bad does the car handle without the front sway bar? Does it make it hard to take fast turns or not... just wondering and i did search.
thanks
james
brandboZ28
12-18-2004, 10:26 PM
I run with mine off all of the time. Its makes a difference but its not that bad with my car being lowered. Just undo the endlinks one day and drive around the neighborhood to see if you like it or not.
Physics
12-19-2004, 04:20 PM
I bought my car without the front swaybar on and just recently put it back on. It really is a big difference, and I cannot imagine driving without it on now. I also had more problems with rubbing (315s in the back) when I took turns hard.
Jameslt1TA
12-19-2004, 05:22 PM
Hey thanks for the replys guys i think ill just try it with the bolts removed and see if i can stand it or not heh.
revtime
12-19-2004, 11:35 PM
Depends on what you want to do with the car, I removed my 1LE sway bar a year ago and never felt the need to put it back on.
I have the car set up for straight line performance though and taking corners is not a big concern for me.
I recently removed the sway bar brackets as well since I knew I would not be putting the bar back on, its not nearly as bad as I thought it would be but like I said I don,t take corners fast anymore.
