Next step? Poly bushings?
SteveZ Z-28
12-18-2004, 03:24 PM
I have the mods listed below and was wondering what the next step would be. I am looking to find some Christmas present possibilities. I am not sure what my next suspension step should be. I am thinking about some poly bushings, maybe Energy Suspension? Which bushings are best? I am not an auto-x person, but I like a good ride and good handling. My bushings are starting to get a little worn I am sure, since I have almost 130,000 on the car. I was thinking about an adjustable panhard bar too, since I have lowered the car with the Eibach springs. Any ideas?
97FormulaWS-6
12-18-2004, 04:30 PM
I'd go with the ES's on the front, but I'd just replace the whole rear suspension with aftermarket. What type of ends you want (Poly or Rod Ends) is up to you and what you want. I went with the rod-ends because I wanted the solid feel of the suspension and the great handling and only drive the car on weekends.
Severous01
12-19-2004, 01:09 PM
i'm planning on getting the spohn's with the poly/rod end LCA's. and i wouldnt suggest poly bushings unless you want to replace them next year, they sag and relax way faster than rubber. they are awesome at first, but my sway bar bushings didnt last a 6 months. i'd suggest also a torque arm if you have the money and want to spend it, it's 300 for a good one like spohn or random tech.
SteveZ Z-28
12-19-2004, 08:59 PM
So I would be better off with stock bushings because they won't get sloppy as fast?
Can anyone second this opinion?
Still trying to find a good Christmas present...
