Need torque specs
AlmostfastLT1
12-17-2004, 09:59 PM
I need torque specs for the following:
wheel hub that bolts to the spindel
upper and lower ball joints
lower control arm mounts to k memeber(I don't think there is a certain spec)
tire rod ends
I am runing a new bmr k member????
Thanks Mark
Z28barnett
12-18-2004, 11:31 AM
Wheel Hub mounting bolts: 63 Lb*ft
Upper ball joint nut: 39 Lb*ft
Lower ball joint nut: 81 Lb*ft
Front LCA Bolt: 74 Lb*ft
Rear LCA Bolt: 85 Lb*ft
Tie rod ends: 35 Lb*ft
Z28
AlmostfastLT1
12-18-2004, 01:52 PM
Z28
Dude, you just saved me alot of time :D
Thankyou so much.
