HELP! New 383 SC is backfiring
lillbush5555
12-16-2004, 08:32 PM
I just got my new motor all in and ready to roll. it is a 383 Stroker all forged with 8.5:1 Compression. I have a Powerdyne 6 PSI SC on there. At idle the car idles good except it has a LOUD back fire I would say every 15-30 seconds. I tried to drive it to the gas station (1/2 mile away) and I didnt even make it out of the neighborhood. The car was backfiring so bad :mad: Then it would just shut off. The car hasnt been tuned yet it is running a a PCMFORLESS tune for my old 383 solid roller motor. Could it not being tuned cause this or is it something else? Someone PLEASE help me as I am totaly Stumped :confused: If it is the tune I saw here somewhere there is a list of basic tunes you can download to build a tune off of but cant remember the site. if anyone has a link to that I would also appericate that as well.
Matt
MEAN LT1
12-17-2004, 12:47 AM
Not being a smart a$$ or anything but have you checked your plug wires and made sure there not crossed up?. It has happend,just one of those small things you can miss while getting your motor togeather.
lillbush5555
12-17-2004, 12:49 AM
Yes I have gone over the waires prob 10 times. The timing is DEAD on I have a double roller timing chain in there with a Electric H20 pump Everything has been checked I was wondering maybe the FMU is set wrong since it is ADJ?
Matt
MEAN LT1
12-17-2004, 12:57 AM
Matt
What kind of fmu is it?, some are adjustable and some arent
lillbush5555
12-17-2004, 07:44 AM
It is the stock 1 from powerdyne but the guy I bought it from bought a fit to make it ADJ? I am not used to all the SC stuff I am just really getting into it. I have the fitting to take it back so it isnt adj.
Matt
NtenseZ28
12-17-2004, 08:04 AM
Who adjusted your valves? Are you still running the solid roller set-up?
tubby
12-17-2004, 08:44 AM
yeah i went over my wires 10 ten times. problem is when you think you're right it's hard to convince yourself otherwise. have some else do it. i always grab someone who knows nothing about cars (like my wife).
mn_vette
12-17-2004, 12:01 PM
Start the process of elimination.
Disconnect the blower, probably just the intake piping to the intake, and the fmu and try it from there.
Does this do it at idle or just while driving?
What was your old cam and new cam on this rebuild? Just to see how far the tune is off.
If it's back firing every 15-30 seconds I'd say that the wires are ok. Does it smell overly rich? Any detials no matter how odd would help.
sleeperz28
12-17-2004, 10:40 PM
check your fuel pressure. Make sure all your blower tubing is all in one loop or your maf will see problems.(no leaks) Also make sure your valves are adjusted correct.
dist0rtion_69
12-18-2004, 01:39 PM
Just out of curiosity did you change injectors since your last setup?
Peace,
Josh
lillbush5555
12-18-2004, 09:00 PM
Well Everyone I found the problem. The oil fill cap had white crap on it so I decided to drain the oil and a 7qt oil pan filled my 14 Qt bucket and then some of nothing but water! SO I have a BLOWN HEAD GASKET :Owned:
Matt
Thanks for all the help I bet no one saw this 1 comming :shock:
dist0rtion_69
12-18-2004, 10:22 PM
The question is.. why is it blown? :)
Peace,
Josh
blown94
12-22-2004, 08:02 PM
Peace,
Josh
Id have to guess faulty torque down of heads, or just got a bad gasket. Its pretty hard to f$*k that up. Its not rocket science to follow a torque sequence. You didnt by any chance re-use stock head bolts or anything silly like that did you?
lillbush5555
12-22-2004, 09:55 PM
Nope when I did the gaskets I used ARP bolts and it hasnt blown yet (ehhe)
Matt
