hambone3441
12-15-2004, 09:56 PM
I will be sending my computer back at the end of jan. to madz28 to get it retuned for my build in feb-mar. The additions to the car will be lt4 hotcam kit, p/p heads, injectors(unsure on size but no bigger than 32#), vig 3200 stall, egr! (program out), air! (program out). My questions is after I get the computer back can I put it in the car and run it before the build? Any potential problems from this? Thanks for any and all input.
Rob
hambone3441
12-16-2004, 06:14 PM
no ideas on this one???????????????????? Come on a little help here. :confused:
Alvin@pcmforless.com
12-16-2004, 07:20 PM
A hotcam tune will be leaner at an idle and some part throttle areas. I wouldn't reccommend runing that programming before you actually do the work.
madwolf
12-17-2004, 02:47 AM
I just replied to your PM. Like Alvin said, it is not recommended that you run a cam tune on a stockish setup. With different size injectors, you can't even run it at all.
