Where to buy parts???
Old Dec 13, 2004 | 05:16 PM
Schurters LT1's Avatar
Just got my Charger kit today(used) T-trim
-oil feed line where should i get this
-reture line just use rub line from charger to pan
-where can i get the fitting for the oil pan
-8 rib belt should have extra
-where can i get the t clamps
-need air filter what is the biggest filter
This is what i have, if you can think of anything i need
-charger
-brackets
-intake pipe
-tb pipe with mondo bov
-hard pipe
should there be a bolt holding the SC pulley on....
Old Dec 13, 2004 | 11:36 PM
Highlander's Avatar
Re: Where to buy parts???
There is a bolt to hold the pulley... you can get all you need at home depot
the fitting from my oil pan (because i damaged the old one and got another one) I got from Home depot... find a 3/8 male fitting with 5/8 hose fitting...
you need a washer and screw for the pulley... i forgot to include the key.. there is a small key and i'm sure you can get that from ANY machine shop at $5.
8-rib belts i will have to get one also as i sent you mine the 8rib i get it from a local parts store...
the return line you can get at home depot.. hey.. you live in canada, don't know if you have Home Depot.. can you confirm?
Old Dec 14, 2004 | 08:05 AM
Birdie2000's Avatar
Personally I had a -8an fitting welded onto my oil pan and am using a -8an oil return line. For the feed I'm using a -4AN line like provided in the kit, with a fitting above the oil filter.
T-clamps should be available from Summit or Jegs, not positive though. Many performance retail outlets have them as well. Also maybe try truck parts stores.
Old Dec 14, 2004 | 01:34 PM
carnutz's Avatar
T clamps are probably cheaper at Peterbilt, Freightliner, mack, volvo type truck dealers. I have a parts guy in my pocket so thats where I get all of that stuff...
They have some silicone hose connectors as well...
Old Dec 14, 2004 | 08:59 PM
flusz28's Avatar
just order parts from vortech...
Old Dec 15, 2004 | 11:56 PM
97WS6SCharged's Avatar
You can have a nice braided line professionally made for about $35 bucks.
Old Dec 16, 2004 | 06:29 AM
By how and where, vortechs line is $65.....
Old Dec 16, 2004 | 08:08 AM
Check out the local diesel supply shop as well as some of the high performance shops. I had mine made at a place that does nothing but specialized plumbing products (hoses, fittings, etc...).
Old Dec 16, 2004 | 08:28 AM
speedmiser's Avatar
Check with your local Parker, Aeroquip, or Swagelock (sp?) dealer. They should be able to make you a hose and suppy needed fittings. They'll probably carry JIC instead of AN though, unless you want to order and wait for AN. Regardless, you can get a much nicer hose than the vortech OE hose, for about 1/2 the cost.
Old Dec 16, 2004 | 12:03 PM
BlownF1's Avatar
I buy my t-clamps and silicone couplers from www.hitempsilicone.com; fast shipping, always seem to have the stuff in stock and their prices are far better than anywhere else I've come across so far. I've always talk to a guy named Jim there...he's very friendly and customer oriented.
Old Dec 16, 2004 | 12:04 PM
BlownF1's Avatar
For the oil feed line, I had a local hydraulic shop make me a new one for $14 including parts and labor. He made it on the spot in just a few minutes. You can select your own length that way as well...
Old Dec 16, 2004 | 12:20 PM
maximumvelocity's Avatar
Link doesn't work.
Queens94z28
Dec 20, 2014 09:11 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
heavenly_six
Dec 10, 2014 12:23 AM
