Fuel leak, wont start
deepstage69
12-11-2004, 02:35 PM
OK its a 95 v6, its had hard starting for a while, Then it would get to where it wouldnt even start, we took it to have the injectors cleaned on a machine that screws into the valve on the fuel rail, that would cure it, for about a month or little longer, but today it started doing the same thing, so i checked fuel pressure, and turned key on, immediatly jumps to a little over 40 and as soon as the pump turns off, pressure starts dropping, and within a minute its at 0 pressure. I pulled the fuel rail loose, to check if it was leaking didnt visually see anything. could it be bad pump?
Any info is greatly appreciated.
Kevin
viper03af
12-21-2004, 08:00 AM
rplace your fuel presure regulator, and make sure vacum lines ar on it too.... it the weird looking thing on your fule rail on the drive side
Tiago
12-21-2004, 12:45 PM
after the pump primes pressure will drop, thats normal.
but when you turn the key it should start priming again and keep pressure high.
viper03af
12-21-2004, 02:43 PM
mine dont drop at all even after 5 minutes like maybe 1 psi if at all
camaros_4_lfe
12-22-2004, 09:40 AM
mine usually take about 5-10 to drop to zero
dunno how long it should take on a stock regulator
