small block 388 10:8:1 f/s
Re: small block 388 10:8:1 f/s
As the owner of a new stroker 385 that is sitting on the engine stand, in comparable state of build, costing a comparable amount of money, I can emphatically state that this is a DEAL!
heads are gm fastburn port and polish
valves are gm 2." hollow intake side/1.55 exhaust sodium filled (not sure on metal grade)
intake flow is 275 @ .60
exhaust flow is 182 @ .60
comp cam valve springs are the only thing else changed and they are part number 941.
rocker arm are compcams pro magnum 1.6 rr's
have exhaust as well. exhasut is comprised of a custom 1 3/4" long tube primary setup to an equally adapted custom y pipe that runs to a single 4" pipe with a spintech 4" single in/out race muffler and 4" exhasut tip. their are no cat's or emissions work on the car. i have this for sale also.
carguyshu
Jan 22, 2017 11:19 AM
