95 Formula stock parts..look and see
Old Dec 8, 2004 | 01:53 PM
crash4cyl's Avatar
Ok I finally got pictures of all the stock parts out of the race car. Everything is make an offer, if it doesn't sell here it'll go on Ebay. So please be respectful in your offers, and please count on paying for shipping so you can add that into your offer.
Set of set-belts for all four seats
Hypertech for 95 LT1..Pending
Trick Flow Intake Elbow
Radiator
Steel Drive shaft
Passanger side Air bag...not blown up
MAF--stock
Heater and A/C Control unit
Full A/C system including Compressor and all
TNT 75-150 Wet kit with NOS Purge kit
Auto Shifter, handle and Cable
Cruise control box and cable
Iron LT1 Heads off a Caprice
2 LT1 Intakes
2 48 mm T/B
Radiator fans with shroud
4L60E With a Vig. 2800 Converter, trans cooler, and Trans go Shift kit.(could use a rebuild)
Washer fluid tank
Starter--works great Pending
Flexplate
Harmonic Damper
UD crank Pulley....unknown manufacturer
Stock PCM pending
Air Pump and tube to go to headers/manifolds
Mac Cat Eliminator Pipe---bolt in for single cat cars
2 cams, one from the Formula and one from a Caprice
2 sets of stock valve covers in great shape
1 LT1 coil pack and ign. module
Caprice Manifolds
Stock Torque arm
Wiper Arms, with blades that could use to be replaced.
triple gauge pod for the a-piller
NOS "Wet" LT1 kit...dry kit that jacks FP up.
2 FP gauges to choose from 1 elec./1 mech.
1 N20 Pressure gauge elec.
As I said it's all open to offers but the all need to go. Any offers will be given serious consideration if an offer is made seriously. Don't forget shipping, so nothing will probably go for less than $6. Located in Chicago Area, so If you want to look, let me know, but please don't contact me if you're only window shopping. All this stuff needs to go.
Chris
Old Dec 8, 2004 | 02:26 PM
maximumvelocity's Avatar
Re: 95 Formula stock parts..look and see
what are the numbers on the iron heads from the caprice?
Old Dec 8, 2004 | 02:28 PM
crash4cyl's Avatar
That I will have to check on for you. They're currently a friends house, and I left my phone at home, so I probably won't be able to let you know until tomm. Sorry about that.
Chris
Old Dec 8, 2004 | 02:36 PM
size and style of fuel pressure gauge electric please...does it have a sending unit of some sort?
Old Dec 8, 2004 | 02:50 PM
crash4cyl's Avatar
The FP Gauge is an Autometer C2 yes it has the electric sending unit. up to 100psi on the face. Sending unit is included, so all you need to do is a little wiring and you're done. It is the 2 1/16 gauge, for the a piller mounting.
Chris
Old Dec 8, 2004 | 03:05 PM
Interested in fuel press. guage & gauge pod, I will await for the head numbers
Old Dec 8, 2004 | 03:07 PM
crash4cyl's Avatar
Alright, I'll get those for you as fast as I can...
Chris
Old Dec 9, 2004 | 07:31 AM
mitchntx's Avatar
PM sent
Old Dec 9, 2004 | 08:18 AM
lt1andy's Avatar
PM sent
Old Dec 9, 2004 | 08:36 AM
texasTA's Avatar
PM sent..
Old Dec 9, 2004 | 10:22 AM
crash4cyl's Avatar
I've responded to all PM's as of current...if you have some more questions feel free to ask.
Chris
Old Dec 10, 2004 | 10:36 AM
crash4cyl's Avatar
ttmft
Old Dec 12, 2004 | 11:24 PM
klpps's Avatar
is the trick flow elbow ceramic and if it is and its in great condition ill give you 65$ shipped for it. kLpps@msn.com
Old Dec 13, 2004 | 05:01 PM
crash4cyl's Avatar
Actually the elbow is satin and a sale on it is pending, I'll let you know if it falls through though
Old Dec 13, 2004 | 06:16 PM
Sent you a pm Chris. Please get back to me with any answers you have at this time Thanks.
