#'s on my AFR 227 ported A.R.E. heads
taner
12-05-2004, 06:32 PM
i finally got my heads flowed... oh brother!!! :mad:
these were apparently "competition ported from AFR" WRONG!!! nf-way! :eek:
on the upside i should be able to make a few more ponies when they are done....properly :cool: . it is obvious they were hand worked but that is it.
ok intake side....
at 0.200 130 AFR #'s 138 down 8 cfm (from advertised numbers)
at 0.300 192 " " 207 down 15 cfm
at 0.400 239 " " 258 down 19 cfm
at 0.500 271 " " 294 down 24 cfm
at 0.600 287 " " 302 down 15 cfm
at 0.700 281 " " 309 down 28 cfm
exhaust side....
at 0.300 129 AFR #'s 150 down 21 cfm :eek:
at 0.400 155 " " 190 down 35 cfm :(
at 0.500 170 " " 207 down 37 cfm :mad:
at 0.600 180 " " 220 down 40 cfm :cry:
at 0.700 187 " " 230 down 47 cfm :alert:
i know there is a bit of variation from flow bench to flow bench but damn! that is just out to lunch! Pete at ARE offered to "fix" the heads, but i am sorry I can't take the chance of seeing what they come out like after they have at them again. :confused: they shouldn't have been that bad.. i think.
with the addition of the Hogan's sheet metal intake i hope it helps the car on motor a fair bit, oh almost forgot the bigger primary tube headers.
interesting enuff tidbit... my home ported/raised roof LT4 intake flow 265 cfm from 500 lift to 700 lift. and i only had a 1.5 cfm difference from the front to rear runners. i know of one other person actually doing what i did with the lt4 intake flowed on the heads and he saw 260 cfm through the intake.
the person flowing the intake is Barry Maskery, an old school engine builder. he is sorta kinda well known in thes parts :D
Highlander
12-05-2004, 06:55 PM
My AFRs 210s flowed more or less the same yours did...
AFR flows them with 4.155 bore, and htat makes a huge difference. mine where 70%cnc and finished by phil.
End numbers where 300cfm@600"lift.
marshall93z
12-05-2004, 07:01 PM
damn...that thing is really gonna fly when you get some better port work done!
exhaust side sux!!!
taner
12-05-2004, 07:35 PM
well i personally know someone who is outflowing the AFR advertised specs with an lt1 block, and it isn't 4.155 bore. i would be happy getting close to the advertised numbers.
Frans96SS
12-05-2004, 07:48 PM
my afr raised runners flowed exactly what they said they would do..... they claimed 325 and i figured they would flow about 310ish so when i got them i put them on the bench at school and beleive it or not they went 325.. the lower lift number were alittle off but they went 325... i put a back cut on the valve and the picked up 15cfm at 2-400 lift and 8 at 5-600 lift..... but they flow alittle more than 325 now :D
rskrause
12-05-2004, 08:00 PM
As fast as you are going, I wonder which numbers are closer to accurate? Your numbers are less than my ported 195's flow (and I am confident in the numbers I have for mine). Something is fishy here! Like I said, maybe they are better than you think.
Rich
OneFlyn95z28
12-05-2004, 09:26 PM
Dang I had a set of LT1 heads flowed here in washington and when they got to TX they flowed pretty much the same!
BTW I mine flowed 268 with the Modified LT1 intake on ;) It is one of my own design :D
ejfagala
12-05-2004, 10:25 PM
Man my 195's out flowed those I would be pissed. More performance did my Comp CNC work and I was a little disiponted that I didn't pick up more then I did.
CFM@ 28''
.200------.300------.400----.500-----.550------.600-----.650
I----E------I---E----I---E----I----E---I----E----I---E----I---E
139-115---205-160-254-185-280-198-283-205-285-210-285-215
taner
12-05-2004, 11:28 PM
rich,
with the cubic inch and 3400 # raceweight i should be running faster than i am. i have full confidence in the **** numbers my heads flowed. keep in mind these were not cnc'ed, that was a f'n lie! i never saw these heads off the car until i removed them last year, shame on me, i have learned a few things in the past couple of years, i guess i can thank ARE for that, lmao!!! most importantly, do it yourself if at all possible! or at least have your hands in on what is being done.
maybe i will call AFR to see what their bare castings flow? couldn't hurt at this point.
also rich, i am tossing a dentists office worth of nitrous at the car to run the number, mind you 2003 to 2004 was a good racing season, i went the same et with almost half as much nitrous being used, from the year before. so i am heading in the right direction, make the most N/A, then throw a dentists office worth of the gas at it, lmao!!! ;)
you bet your ass i am pissed! but what can i do!
the numbers are relative, if when finished i pick up 20 - 30 cfm on the same flow bench, i will be satisfied. Barry was building race motors when i was merely a gleam in my father's eyes, lol!!!
marshall,
i am with you..after all is said and done, i'll let the et's prove or disprove what this measuring device is showing before and after, which should be in just over a month, until i get new flow numbers.
INTMD8
12-05-2004, 11:39 PM
Yeah, your definitely going to find some power in those heads.
For comparison, these are the flow #'s for my heads, which started out as AFR cnc 195's, and a friend of mine ported them by hand afterwords. The intake runner is 217cc.
Intake Exhaust
.200 134.4 99.6
.300 185 134.1
.400 232.6 169.7
.500 263.4 195.8
.600 277.3 201
.700 288.6 209
I'm having some more work done on them now as I have my engine out for freshening.
Highlander
12-06-2004, 12:27 AM
Intake Exhaust
.200 134.4 99.6
.300 185 134.1
.400 232.6 169.7
.500 263.4 195.8
.600 277.3 201
.700 288.6 209
How many miles before freshening?? again??
INTMD8
12-06-2004, 12:38 AM
13,000 miles on the engine. None of which were easy.
So far I've just removed the heads, and everything looks fine.
1racerdude
12-06-2004, 04:39 AM
My head porter says AFR has a "HAPPY" flow bench,because they won't flow advertised on his bench. He has done a ton of them too.
Birdie2000
12-06-2004, 08:23 AM
Wow, my hand ported 193cc runner AFR's went as follows:
Intake Flow #'s:
.100 - 68
.200 - 147
.300 - 197
.400 - 236
.500 - 265
.600 - 276
Exhaust Flow #'s (No pipe):
.100 - 58
.200 - 106
.300 - 148
.400 - 178
.500 - 198
.600 - 210
Can't wait to see what that beast runs with some REAL heads on that thing!
SAR2K
12-06-2004, 09:49 AM
Taner were these "competition ported" AFR's that someone then went through by hand?
taner
12-06-2004, 11:57 AM
well if they were comp. ported, there is absolutely no signs that they were cnc'ed. that is why i hard it almost impossible to believe that they were cnc'ed especially with the exhaust flow numbers being as low as they are.
i honestly can't believe these things were cnc'ed...period! obviously gone through by hand.
BigRick
12-06-2004, 12:42 PM
They could have been CNC'd and then hand ported, you'd never know. The hand porting could have hurt more then helped. One way to find out is to CC the heads and see what the intake CC is. Your 227's could be around 230 cc intake.
On a side note we just CC'd my AFR 220's that have been ported a bunch. The intake came out right at 220 CC's. They flow around 315 CFM @ 700. Now that's really good for the intake CC runner size.
SAR2K
12-06-2004, 02:55 PM
They could have been CNC'd and then hand ported, you'd never know. The hand porting could have hurt more then helped. One way to find out is to CC the heads and see what the intake CC is. Just what I was thinking.
tonyss1
12-06-2004, 04:46 PM
Taner, I had the same shock when i had mine reflowed and re-ported. Nick had done minimal port work they only flowed about 280 on the intake and about 190 on the exhaust. If you find a good head porter you should get well over 300 on the intake and close to 230 on the exhaust. You can see from my sig it woke it up a bit. T
Birdie2000
12-06-2004, 04:52 PM
I bet the nitrous will love the better exhaust ports you're gonna have along with the headers. :)
taner
12-06-2004, 05:04 PM
very true, tony knows what i am talking about. hell yeah the n2o will surely benefit from the ability exit the motor as quickly as it is being pumped in! lol!!!
Tony,
i have to give you a call!
my exhaust ports = fountain straws! :mad:
Denny McLain
12-06-2004, 08:10 PM
ok intake side....
exhaust side....
They say misery loves company, so I hope ya don’t mind that I join ya.
MY ARE 227’s (all $4,000.00 American Dollars of them) flowed pretty close to what yours did (285 cfm max intake and 188 max exhaust) The guy screwed me on a whole bunch of other things before I got a clue as to what was going on.
So don’t feel like the Lone Ranger here. I won’t go into my usual rant, but Nick and a bunch of the other ARE lowlife’s should be in jail.
The boy sure did talk the talk didn’t he? I was promised 320 cfm and 500 rwhp NA. Promised!
Z8'S
12-06-2004, 09:07 PM
My new AFR 220 's Ported by Craig Gallant (GTP)on the intake are over 300cfm by .500 lift intakes
230cfm by .500 lift exhaust
I wont tell ya where they are at any of my cam specs but these are a badass set of heads :D
P>S its a 223 cc port :p
taner
12-06-2004, 09:13 PM
Denny,
believe me i know we aren't alone! there are far too many of us! :mad:
Boost It!
12-06-2004, 10:35 PM
whenver someone promises me results in motorsports, i leave.
INTMD8
12-06-2004, 10:45 PM
Wanna sell them?
I know you want to start over with a set of AFR 215RR's :)
ejfagala
12-06-2004, 11:42 PM
More performance did my heads and they did a great job and for $2800, including upgraded springs, Titanium retainers, and Ferrera valves.
taner
12-07-2004, 09:21 PM
was that just the port work, and parts? or heads included?
thanks
taner
Denny McLain
12-07-2004, 09:23 PM
[QUOTE=Z8'S]My new AFR 220 's Ported by Craig Gallant (GTP)on the intake are over 300cfm by .500 lift intakes
Please spare us and don't tell cam spec's. We are not worthy.
I've been disappointed hearing people have had problems with GTP heads as I honesthy do like Craig. But for years I wanted him to do some AFR's for me, he kept wanting to do LT4's instead and that's why I had ARE do some for me. So ya think that was a bad move maybe???
Great flow numbers and I won't tell you my cam spec's either. Did you have them flowed afterwards or these the numbers included with the heads? :bow:
bunker
12-07-2004, 09:27 PM
I think you should send them to Lloyd for some porting, all I can say is I have 2 sets of LT1 heads ported by him and he's awesome!
Check out this thread and what he did to AFR 210's that were bare, all for under 2k I bevelive it cost the guy for cores and have lloyd do the porting:
http://web.camaross.com/forums/showthread.php?p=2675283&posted=1#post2675283
Denny McLain
12-07-2004, 09:34 PM
I tnhink you should send them to Lloyd for some porting, all I can say is I have 2 sets of LT1 heads ported by him and he's awesome!
I'm still an ARE fan. The dude rocks! Dude.
taner
12-07-2004, 10:02 PM
lol! :D
Tweaked Zed
12-08-2004, 12:56 AM
Taner,
Craig did a nice job on Mark's LS1 heads. Nice flow numbers...nicer velocity from what I here. Just hope your 227s aren't hacked too far for someone to fix. By the looks of those numbers, you'll probably be good. ;)
Bryce
bunker
12-08-2004, 02:38 AM
ARE blows I hear, I'm Canadian too but I aint defending them ehh? :)
meengreen 94z
12-10-2004, 08:09 PM
Yeah Daren Wlodarczyk(9 sec TA convert.) took his car there to have his F.A.S.T. system installed, they pulled his engine and sold it to another customer as new. Not sure how they thought they would get away with it.
12Second3rdgen
12-11-2004, 01:29 AM
I have seen 10% variations between flow benches here in town.
jimlab
12-11-2004, 02:33 AM
FWIW, here's what B&B got out of my 215s...
http://home.gci.net/~jimlab/images/Engine/Delivered/Head_flow.jpg
taner
12-11-2004, 08:07 AM
nice numbers!
4drLT4
12-11-2004, 10:43 AM
Please tell me that not even ARE is stupid enough to pull that kinda crap...especially with one of their "signature" clients?? :eek:
taner
12-11-2004, 11:31 AM
heard something about that, while it was under previous management. :(
meengreen 94z
12-11-2004, 12:47 PM
Yep, read the first post on the page:
http://web.camaross.com/forums/showthread.php?t=305819&page=10&pp=15
Denny McLain
12-11-2004, 01:41 PM
You know....... I'm trying to figure out what they HAVEN'T pulled?
New management, old management.... it's still the same bunch of crooks. Simply blows me away the stories I hear.
taner
12-12-2004, 08:51 PM
pete k offered to redo the heads....the work to be done is already in motion..and I can't take the chance of it not being done in a timely manner, and to my satisfaction. too much has happened :confused:
taner
12-15-2004, 10:54 PM
well i haven't got the actual numberson paper in hand but i spoke to Barry, i picked up a ton on the exhaust side and numbers on intake side are flowing to at least the numbers i would see from a set of cnc'ed heads from AFR. the exhaust side flows better than the advertised numbers from AFR :) and he is not done yet...now it is time to focus on velocity of the air in the port! :)
peak at 700 was 308 intake, and 234 exhaust (no pipe) that is just from what he told me from memory. i hope to have the numbers tomorrow. i got lucky, he ported them ahead of schedule as he was getting other big projects coming in all at once!
meengreen 94z
12-16-2004, 08:06 PM
Good luck with it.
ejfagala
12-17-2004, 12:39 PM
thanks
taner
That was everything, heads, port work, and parts to my door.
ejfagala
12-17-2004, 12:44 PM
Now that's more like it, I think you made a great decision getting them redone and not just sticking with them.
taner
12-17-2004, 02:03 PM
without a doubt! :) hopefully I can start putting the top end together right before the new year!
taner
12-19-2004, 12:43 AM
ok intake side....
at 0.300 192 " " 207 down 15 cfm NOW 204
at 0.400 239 " " 258 down 19 cfm 251
at 0.500 271 " " 294 down 24 cfm 291
at 0.600 287 " " 302 down 15 cfm 303
at 0.700 281 " " 309 down 28 cfm 308
exhaust side....
at 0.300 129 AFR #'s 150 down 21 cfm NOW 144
at 0.400 155 " " 190 down 35 cfm 183
at 0.500 170 " " 207 down 37 cfm 205
at 0.600 180 " " 220 down 40 cfm 225
at 0.700 187 " " 230 down 47 cfm 230
this was done on an super flow sf300/600. also a 4.030 bore was used, mopefully it will flow better with a slightly larger bore. AFR uses a 4.125 bore for their flow measurements.
thanks to Barry Maskery for his work on the heads.couple the head work with the new intake and new headers and the spring couldnt come soon enough! :cool:
JWINN
12-20-2004, 04:41 AM
I'll be happy if and when my AFR's from Nick actually show up at my door by this Tuesday as promissed.
More than likely I see another road trip to ARE this week. I have to act fast becuase Nick is moving his shop to another location as I'm told, he has to be out of his current building by the end of the month.
What experience to say the least!
JWINN
12-20-2004, 05:00 AM
From my understanding they did get away with it. WTF! Talk about feeling bad for the guy. If I was Darin I would wait outside of Nicks new job with my new baseball bat to see if he wants to play baseball with me and my other friends that came along for the game?
There is no way I would stand for that **** if I was in his shoe's. Considering all this takes place in Canada and Darin doesn't have a legal leg to stand on as I understand it, due to the fact Darin is not a Canadian resident but a US citz.
As that old saying goes bad things seem to happen to bad people.
taner
12-23-2004, 10:35 PM
i am a firm believer that what goes around comes around! I can't speak for daren, but i am sure there is some way he can attempt to obtain restitution, even if it means waiting a long time!
Jim,
i can't believe you are still waiting for parts from there! wtf! hopefully you get them!
