sub frame connectors
Black02Z
12-04-2004, 02:12 AM
now i know what they do but where exactly are they installed pics would be helpfull :confused:
lbrowne
12-04-2004, 11:06 AM
Just for info, your car will tighten up alot after these..... (SFCs in general)
1stls1
12-04-2004, 10:42 PM
Can you install these on the ground, or does the car need to be in the air? Is it poss to install wrong, meaning, the car on being straight?
Frank89IROC
12-04-2004, 11:27 PM
I installed Jegsters bolt on(from JEGS), in my driveway. I did jack up one side of the car that I was working on with jack stands. They can only go on correctly. If you try to place them wrong, it just won't line up. (On my 94TA).
lbrowne
12-04-2004, 11:55 PM
For SFCs to be installed correctly, the car neesd to be under load. Meaning under its own weight on a level surface. A lift in a shop is perfect :)
1stls1
12-05-2004, 08:35 AM
By a lift, you are talking about a drive-on lift. With the bolt on, are they just bolt on like it says, or do you have to remove something and "share" the hole?
87DJP2001
12-05-2004, 09:03 AM
If you are going to get SFC's have them welded on. Bolt on ones are a waste of money in my opinion.
lbrowne
12-05-2004, 12:14 PM
I have bolt ons and I love them. The difference in the car is night and day.
Also by lift yet thats hwat I mean, a drive on one. :)
KPZ-28
12-05-2004, 12:41 PM
Sorry about the hijack, but did your bolt on connectors eliminate any dash squeaking or is it better to weld them on?
87DJP2001
12-05-2004, 12:56 PM
You may love those bolt on SFC's now, but given time they will start getting loose. And then you will have the same flex :cry: as before.
JoeliusZ28
12-05-2004, 02:31 PM
ive got pics in my cardomain if you want em (page two of sig) - kenny brown double diamond weld ins
Super Slow '97
12-05-2004, 05:52 PM
Can't you buy some bolt on sfc's and then just have them welded or are they different?
lbrowne
12-05-2004, 05:58 PM
You can weld your bolt ons on :), many have done it.
Frank89IROC
12-05-2004, 06:39 PM
I have the Jegster bolt on sub frame connectors, After installing them myself, I went to a muffler shop, had them welded for $20.00. You'll notice the car will be much stiffer on bumps.
