Does your car's heater blow colder thru the floor than the vents ?
NEWBIE T/A
12-03-2004, 11:07 AM
Mine does, and it is weird - I'd guesstimate that there is a 10 degree differential.
Makes life tough on chilly mornings ! :cry:
( I hate cold weather, anyway.)
Also, on my car, it takes the knob being about 3/4 to 7/8 of the way into the red zone for any heat to be put out - is that normal ?
My '91 Suburban will fry you out of the truck, and at 1/2 slide you can feel the warmth.
:confused:
Thanks !
Britt
xfreshjiv12x
12-03-2004, 11:46 AM
do you have a hypertech programmer or somthing that lets you adjust the fans to run cooler? It makes your heater run cooler too.
NEWBIE T/A
12-03-2004, 11:52 AM
It is set to optimize the factory 195 stat temps.
Their website does not show the specifics, but it seems like fan 1 comes on around 205 degrees as opposed to the factory's 218 or so. I would think 200 degree temps would be plenty sufficient for heat.
I have a 195 stat in the Suburban, and it blows plenty warm.
Britt
xfreshjiv12x
12-03-2004, 12:18 PM
I dont know? But I know on my 95 and my cousins 94 it blows MUCH cooler. :confused:
Z28SORR
12-03-2004, 01:01 PM
I'm confussed, my heater blows hot air, my A/C blows cold! You should be getting plenty of hot air with the temp selector at full hot. I have to turn mine down after engine warms up. Normally to about the 1 o'clock position. If you are getting different temps. from the upper and lower vents you probably have a sicking HVAC door. These are internal to the HVAC housing and a pain to diagnose and get at.
