shift light hook up where does the green wire go
MAGIC Z
12-03-2004, 12:28 AM
alright i need to no where the green wire goes to to hook up a shift light on a 96 z 28 two wires of the coil are green and pink which one if those r the ones im looking for
teke184
12-03-2004, 07:24 AM
why not just run it to the ECM.
OBD 1: White wire, red connector on PCM, pin #13
OBD 2 LT1: Same as OBDI PCM
98 LS1: Tach line is Pin 35 on the BLUE connector. Tach line is a white wire
99-00 LS1: Tach line is Pin 10 on the RED connector. Tach line is a white wire
just use a splice and it's nice and easy.
MAGIC Z
12-03-2004, 08:16 PM
there we go red connector pin 13 thats what im looking for others where telling me pin a13 white where now i can finish the job thanks
