Gripenfelter
11-23-2004, 10:42 AM
Maybe we can get a GP going for 383s since there have been a few people asking recently.
I need the following:
CA-LTDS375 Callies "Dragonslayer" Forged LT1/SBC Crankshaft 3.75" Stroke (Will consider SCAT)
EG-LTH600 Eagle ESP LT1/SBC Forged H-Beam Rod Set 6.00" Length (I only need ONE rod)
SRP-37560-5 SRP Forged Piston Set -5cc Valve Reliefs
4.030" bore x 3.75" stroke, for 6.00" Rod
FM-7100CH Federal Mogul LT1/SBC Rod Bearing Set, Competition Series, Super Duty Alloy, Chamfer (STD) (Will take Clevite 77 as alternative)
FM-152M Federal Mogul LT1/SBC Main Bearing Set, Competition Series Super Duty Alloy, 3/4 Groove (STD) (Will take Clevite 77 as alternative)
Felpro LT1 Camshaft & Cylinder Head Swap Gasket Package
Fel-Pro Intake Gaskets, Fel-Pro Timing Cover Gasket, Opti Seal, Crank Seal, Water Pump Drive Seal, GM Coolant Crossover Seals (4), GM Throttle Body Gasket, GM EGR Gasket, GM LT1 Head Gaskets, Fel-Pro Exhaust Header Gaskets
GM-10128285 GM OEM Stock Replacement Timing Chain for LT1
J-E-J10008-4030-5 JE Plasma Moly Ring Set 4.030" Bore, 1-16 x 1-16 x 3-16 File Fit
