Is there a difference in 93-97 rear ends? (3.23 ratio)
Just wondering as i'm picking up one for my 95 in a day or two. It's listed as "93-97" rear, but just want to make sure. I'll be transfering the brakes on my current rear over to the one i'll be picking up wednesday. It's also a factory 3.23 ratio rear, 104k miles. My current rear has 113k, so the milege doesn't worry me.
Thanks,
Jason
Thanks,
Jason
Re: Is there a difference in 93-97 rear ends? (3.23 ratio)
hmmm.... the one i'm looking at is said to be "non TC", and the brakes are already off the rear... i plan on putting the brakes from my current axle onto it when i go pick it up.
So should it bolt into my car with no problems, given these circumstances?
Thanks for the replys
"TC" is traction controll. I dont believe that was offered until 96 so your car wouldnt have it. Take a look under your car and see if the ABS sensor plugs into the top of the pumpkin (most likely will), and just make sure that the new one also has the sensor on top.
