Huntr1117
11-22-2004, 12:59 PM
Is there anyway to change the wheel studs on my car without pulling my whole diff. apart? I have 2 broken wheel studs and I need to change them. My car has traction control with that gear that keeps the studs from being knocked out the backside. Any suggestions?
Injuneer
11-23-2004, 05:05 PM
Have you tried a "search"? I'm sure I've seen someone post the "trick" to getting the studs out on the traction control cars, without pulling the axles.
omatter67
11-24-2004, 01:18 AM
Just did it myself, Put a deep socket on the other side of the hub and take a hammer and bang them out, there pressed in so just pop them bad boys out the back then put the new one's through from the back put a bunch of washers on the stud and tighten the lug on the stud itself till the studd appears to be fully pressed in. good luck
Huntr1117
11-24-2004, 12:57 PM
That doesn't work if you have traction control. There is a gear that stops the stud from comming out the back.
