Inutero
11-21-2004, 07:35 PM
http://www.adrwheels.com/wheels/?sfID1=12&sfID2=206
thanks
thanks
Would this wheel fit my 95z?Inutero 11-21-2004, 07:35 PM http://www.adrwheels.com/wheels/?sfID1=12&sfID2=206 thanks Injuneer 11-21-2004, 08:29 PM I don't see any with the 4th Gen bolt pattern (120.65mm), although some people have used the 120mm BMW bolt pattern. I wouldn't, but some people have. Then, they don't appear to have anything more than a 38mm offset, and not anything even close to that in a 9.5" width. Which specific wheel size are you looking at.... most of the wheels on that page won't fit, but maybe you have a specific width/offset in mind? Inutero 11-22-2004, 08:32 PM well I would like the 9.5 " wide ones.... but I guess none of them fit. thanks Inutero 11-22-2004, 08:34 PM Oh another thing, what size offset should I be looking for that would look good on my car? I see the 9.5" has a 15mm offset, I guess that would be no good? 95lt1aholik 12-13-2004, 12:33 AM i have 20X8.5 adr sterling chromes on mine and they dont rub at all Injuneer 12-13-2004, 01:47 PM What rubs is determined by the "offset", the outside diameter of the tire, and the width of the tire.... for a 9.5" wheel on a 4th Gen, you need an offset in the range of 40-56mm. A 40mm offset will put the outer edge of the front wheel/tire just at the very edge of the fender, maybe a shade outside. A 56mm offset will move it in about 5/8" from the edge of the fender. 95_LT1_6SPD 12-15-2004, 12:28 AM StangKilla has some 19" adr's on his car. They look good. Maybe he will chime in with what offset and stuff, or do a search and you will probably find it. | ||
