We are now carrying HID lighting kits!
tbyrne
11-21-2004, 05:20 PM
TBYRNE Motorsports is now carrying HID kits for many different vehicles. We list some of the popular kits on our site but can get them for most vehicles. Part numbers and pricing for the 9005 and 9006 packages are -
XD-4k-9006 9006 4300k HID Conversion Kit (low beam) $429.99
XD-4k-9005 9005 4300k HID Conversion Kit (high beam) $429.99
XD-6k-9006 9006 6000k HID Conversion Kit (low beam) $549.99
XD-6k-9005 9005 6000k HID Conversion Kit (high beam) $549.99
XT-65k-9006 9006 6500k Xtreme HID Conversion Kit (low beam) $399.99
XT-65k-9005 9006 6500k Xtreme HID Conversion Kit (high beam) $399.99
XT-8k-9006 9006 8000k Xtreme HID Conversion Kit (low beam) $399.99
XT-8k-9005 9006 8000k Xtreme HID Conversion Kit (high beam) $399.99
Our 4300k / 6000k HID conversion kit uses genuine Philips bulbs and ballasts. This product includes a complete wiring harness that will literally plug directly into your OEM headlight harness via proper mating connectors. The harness provided includes upgraded fuses and relays to ensure you do not draw a higher current from your stock harness than it was designed to provide.
2 Philips Capsules
2 Philips Ballasts
Complete wiring harness
Complete instruction manual.
The Xtreme HID 6500k HID Conversion Kit is geared for an intense purple output and the 8000k HID Conversion Kit is geared for an intense blue/purple output. These products include a complete wiring harness that will literally plug directly into your OEM headlight harness via proper mating connectors. The harness provided will include upgraded fuses and relays to ensure you do not draw a higher current from your stock wiring harness than it was designed to provide.
2 6500k Clear HID/Xenon Bulbs
2 Ballasts
Complete Wiring Harness
Complete Instruction Manual
More info can be seen on our website.
kmook
11-21-2004, 07:42 PM
Still nothing for us firebird people i assume? :(
tbyrne
11-21-2004, 07:49 PM
What year is the car? I can check on this tomorrow.
kmook
11-21-2004, 07:54 PM
96'
89TransAmWS6
11-21-2004, 11:15 PM
yes please check into that..i have a 93 firebird but im sure its the same as a 96..?
thanks :D
atljar
11-22-2004, 12:15 AM
Looked on the website, but dont see more details? Can you post a direct link? Any issues running these in any housing that accepts the 9005/9006 bulbs?
tbyrne
11-22-2004, 10:09 AM
The HID section is right off of the main page. Just scroll down the left hand column and you will see a link to that section. They can be used in any housing that accepts the 9005 and 9006 bulbs. Other kits are available if needed.
I'll check on those Firebird kits today.
atljar
11-22-2004, 12:16 PM
thanks, i am blind :)
jakef2003
11-22-2004, 04:27 PM
I too, would be interested in an LT1 bird setup.
89TransAmWS6
11-23-2004, 03:29 PM
Any luck?
tbyrne
11-23-2004, 04:06 PM
Nothing yet.
captain_foustas
11-29-2004, 02:36 AM
im also interested in a firebird setup
tbyrne
11-29-2004, 08:14 AM
There has been alot of interest in the Firebird HIDs so I'll be continueing to work on this. I might have a lead on the housings.
Highlander
12-05-2004, 03:54 PM
OK OK.. big question!!!!
do i have to buy 2 kits in order to have highs and lows????????
tbyrne
12-05-2004, 04:19 PM
I'm working on seeing if we can have kits made for the LT1 Camaro along with the Firebirds. The LS1 Camaro will need 2 kits - 9006 for the low beam and 9005 for the high.
Ryan94ZA4
12-05-2004, 04:29 PM
IF you want to run HID's in your 93-7 Firebird, I would go with an aftermarket GLASS housing for an H4. Then, you can get an H4 HID setup and go with either the single beam (you will have no highs) or the dual beam setup (you'll have high beam but the cost about the same as 2 single beam systems.)
I have a low beam HID kit on my 94 Z with the 98-02 front end and also put a set in my wife's 94 Vert. All you have to do is take a heat gun and heat the stock housing up at the bulb then use a prying tool to slowly release the bulb from the housing. Then, I ground off the locking tabs from the HID bulb so it was the same diameter as the neck of the factory housing. Leave the O ring on the HID bulb to keep things seal and also to help hold the bulb where it needs to be. I then used epoxy (you could use silicone but I dont' know how long it would hold) to permanently put the bulb in place. Pay attention when you epoxy the bulb in as most of the wires come out at a 90 degree angle. If you put it in wrong, you have to cut your headlight mounting panel so everything fits well. I mounted my ballasts and starters behind the radiator support so if I get in a wreck they will hopefully be safe.
I can supply some pics if anyone wants to see.
Ryan
Highlander
12-05-2004, 04:36 PM
Does the LT1 still need 2 kits?
Ryan94ZA4
12-05-2004, 04:39 PM
IF you want true HID's in both your low and high beams, yes. I just have low beams in both of my cars and used the dimmer switch for a 93-97 Camaro as it lights both the lows and highs on high beam. If I ever get the extra money, I will buy high beams....
Ryan
Highlander
12-05-2004, 05:06 PM
i knew it was too cheap to be true :(
I guess i'll buy low beams first since its the ones you use the most...
what else did you do to make the high beams light up with the low beams?
Ryan94ZA4
12-05-2004, 07:36 PM
If you have a 93-97 Camaro, it already is set up to light all the lights on high beam. If you have a 98-up Camaro or a Firebird or TA, you can just upgrade to the 93-97 Camaro dimmer switch.
Ryan
Highlander
12-05-2004, 09:45 PM
My camaro shuts down the low when using high...
Ryan94ZA4
12-05-2004, 11:06 PM
If you are talking about the car in your sig, it is the incorrect dimmer switch for your car. I'd go get another one and make sure to get it for the 93-97 car.
Highlander
12-06-2004, 12:12 AM
factory dimmer switch ;) i have it since new... i'll check it out anyways....
89TransAmWS6
12-22-2004, 05:06 PM
Anything new about the hid lights for lt1 powered trans ams? Or any leads on where to get glass h4 housings?
tbyrne
12-23-2004, 09:49 AM
Nothing yet. We probably get the most requests from TA users and wish they can be supplied.
captain_foustas
12-23-2004, 03:32 PM
so nothin yet or nothing period?
Myxtreme1
12-24-2004, 08:44 PM
<~~~Here's another interested TA person.
MysticTeal 95 V6
12-24-2004, 09:45 PM
I think a HID upgrade on the LS1 T/A's would look pretty sweet :D
Myxtreme1
12-25-2004, 12:03 AM
Yep...and a complete front end upgrade for the lt1 TA's, lol.
Ryan94ZA4
12-25-2004, 01:18 AM
Hella sells a glass housing for the 93-7 Firebird/TA. You will then have to buy either a single beam H4 HID kit (no high beams....) or a dual beam H4 HID kit (high beam and low beam but double the price)
I would do this to my TA but I don't plan on keeping it. I have HID's in my white Z and the wife's vert; one is an old 4th gen front and the other is a new 4th gen front. Definitely a good upgrade if you do a lot of night time driving.
Ryan
jakef2003
12-27-2004, 06:58 PM
Ryan
Link to said Glass housings please ?
airos4
12-30-2004, 07:14 PM
I'd be interested in a set for the lowbeams on my 97 Camaro Z28... I know you said you were looking into it, so just add me to the interested list.
96SilverRam
12-31-2004, 02:57 PM
Correct me if I'm wrong but, if you have a hella glass housing that excepts H4's then why not do the Bi-Xenon H4 hid kit. I thought most of these kits sell for $350 to 599 depending on where you buy. :cool:
PediDr2
12-31-2004, 03:57 PM
I think a few have gotten their stuff from here
http://www.danielsternlighting.com/products/products.html
jakef2003
03-24-2005, 02:44 PM
Anything new for us Firebird guys? I'd KILL for a set of HID's. :(
tbyrne
03-28-2005, 10:38 AM
Haven't come across anything yet :(
