How difficult is it to add power locks to a car without them?
Old Nov 21, 2004 | 12:23 AM
91 Camaro RS's Avatar
My Camaro doesn't currently have power locks, how hard would it be to add this feature in? I found the original switches on eBay along with original lock solenoids. Can anyone tell me if this is even worth trying to do?
Old Nov 21, 2004 | 01:23 PM
Re: How difficult is it to add power locks to a car without them?
anyone?
Old Nov 21, 2004 | 09:37 PM
Rice Killer87's Avatar
im sure u can do it,its pretty much up to u if u want them or not. if it was me and my camaro didnt have power locks i would look into it.
i say do it
Old Nov 21, 2004 | 10:22 PM
I'll have to figure out how to wire it up so that both switches unlock/lock both locks at the same time. There was someone on eBay who was selling a power window and lock setup (OEM pull) along with the factory wire harness, but it got to expensive for me.
Old Nov 22, 2004 | 03:42 PM
ishz28's Avatar
It'll take some work. First you'll need the harness for the doors. Then you'll need to undrill and then repostion and drill a power motor/regulator. Diffrent door panels, switches and plate. I think that's it.
Old Nov 22, 2004 | 04:38 PM
Zepher's Avatar
We installed power locks into my friends 86 Z28.
We got all the parts from a 91 Firebird.
There is a relay for the locks as well as the 2 lock solenoids, a wiring harness that has 4 wires I believe, that run along the firewall behind the dash.
We cut the harness on the driver and pass side and just added our own wires to run behind the dash since the stock wires in the 91 were all wrapped in with the IP harness.
Door panels are the same, no difference there, and on the door lock panel, we just pulled out the blank plates and put the switches in.
Took us a few hours to remove the system and then a few hours to install it in the 86.
Old Nov 22, 2004 | 06:05 PM
I think I may just buy the driver side switch, and not put the switch on the passenger side, and do the wires myself since I can't find the factory harness. I found the actuators and the switches on eBay.
Old Nov 23, 2004 | 10:49 AM
ishz28's Avatar
You'll have a nice hole in the door panel from the crank if you don't change panels.
Old Nov 23, 2004 | 10:57 AM
Zepher's Avatar
They may have inserts available still for the crank hole.
The panels I have in my 88 came out of an 82 and in the crank hole are little bird emblems.
Old Nov 23, 2004 | 12:32 PM
What? Why in the world would I have a hole in my door panel?
Old Nov 23, 2004 | 08:27 PM
RamAirTA95's Avatar
http://www.partsexpress.com/pe/showd...number=330-013
Old Nov 23, 2004 | 09:06 PM
ishz28's Avatar
If you don't change panels you'll have a hole where the crank arm for the window used to be,
Old Nov 23, 2004 | 09:32 PM
I'm adding power locks, not power windows. I really don't want power windows anyway.
heavenly_six
Dec 10, 2014 12:23 AM
ro2207
Dec 4, 2014 06:18 PM
Dec 4, 2014 11:56 AM
USAirman93
Nov 24, 2014 03:37 PM
Black93lt1
Nov 21, 2014 07:30 PM
