How much HP and Torque Can stock block take?
PROCHARGEDIROCZ
11-18-2004, 05:34 PM
Im putting together a 355 supercharged smallblock using the factory 1 piece rear main seal. I wanted to know what is the limit in terms of power can be made before the stock block starts to get flimsy. I was thinking about getting the new GM sprorts man block for 1 piece rear main seal, but the price is one factor. The motor in question has a stout bottem end with Being fed by an ATI.I plan to run 12-15lb. And am shooting for 600 crank hp.But I want to be able to turn it up if I choose.Thanks
rskrause
11-18-2004, 05:36 PM
Do a partial block fill if you are worried, but in general you should absolutely no worries with anything less than ~1,000hp.
Rich
Fast Caddie
11-18-2004, 05:45 PM
The generally accepted max was about 1100 crank hp. But now that BigRick's turbocharged 'bird is going low 8s at nearly 170, that rule might be changed a little bit....
AdioSS
11-18-2004, 07:37 PM
they said that was with only a "950ish rwhp" tune, not the latest 1200+rwhp tune :)
PROCHARGEDIROCZ
11-18-2004, 08:13 PM
Thanks for the replys.But only thing is Im planning on using the 1 piece rear main seal block from 86-92 not the LT1. If 900-1000 is the limit why would anyone use the Bowtie?My feeling were this. I have to buy the block from my builder at $250. He has to machine it and go over it. And If I wanted to upgrade the caps you are talking atleast 500+ for caps and machine work. Thing is the Bowtie sportsmans comes with a finish bore of 3.98 and doesnt need to be decked or anything like the stocker, plus it comes with angled caps.Im looking at 1000- 1200 for block and machine work if I go with aftermarket caps. Sportsman comes with this already but the down side is I have to get a custom ground cam with bigblock bearing lobes and use aftermarket hydrlic rollers for the cam which can be expensive. The bottomline is I dont want to dump alot of money into a stock block.Thing is I thought the outer limit of the stocker was around 600hp. I just want to put it together once and be done with it and not have to worry about block integrity since it will be street driven, and It is very likley I will be upping the boost in the future since I have the JE pistons with the 52 series .180 wall pins and oliver rods with WSB bolt upgrade, so bottom end integrity is not a problem. How many here have Bowtie blocks?Thanks for all replys
OneFlyn95z28
11-18-2004, 09:14 PM
yeah Ricks did NOT make it through the weekend. I was pretty bummed. I wanted to see 7s!
rskrause
11-18-2004, 09:26 PM
You asked what hp the block was good for, not if it made more sense to build it up vs. buying the Bowtie or an aftermarket block. Sounds like the Bowtie, or equivalent, would be a good choice for you.
Rich
Fast Caddie
11-18-2004, 10:00 PM
You mean it blew up?!!!!!!
PROCHARGEDIROCZ
11-18-2004, 11:48 PM
Rich
Sorry If I wasnt more specific.But I think my concerns go hand in hand with each other.I dont know why I have the 600hp stock block limit in my head, but I thought that was the limit. Has anyone here split or cracked the stock block pushing over 600hp? What I should have asked in posting this thread was if investing money into a stock block to handle x amount of hp would be better off spent on a bowtie.Thanks for the reply.
SStrokerAce
11-19-2004, 12:33 AM
The HP limit has to do with a lot of things, type of power (boosted vs. N2O), filled or unfilled, how good the maching is on it etc.... but basically a block is good for about 1100-1200hp maybe a bit more but it's still a time bomb. Rick's 950rwhp was in that 1100-1200hp range, i've had a customer tell me his NuTek bottom end let go at 1130hp, so I would say 1000hp and your going to be inside the thing checking everything is the limit.
Since you are playing with a SBC it only makes sense to me that you would use a Bowtie, Dart or World block. The Bowtie Sportsman is a good deal, but the 8320 Steel Caped CNC Bowtie is even better. On top of that a 375 cube motor would be a great blown/turbo platform (4.125" Bore x 3.50" stroke) and that block would still have tons of cylinder wall in it, perfect machining and more strength than any filled block would get you. Bascially it's going to take you the $$$$ to get the stock block up to that blocks specs and you are still going to have a weaker unit.
Oh on top of that the priority main oiling is just a little benefit to help take the power.
Bret
PROCHARGEDIROCZ
11-19-2004, 02:01 AM
Thank you very much for the informed reply. Im leaning towards the 1 piece rear seal bowtie since the crank I have is one piece rear seal. I think the block comes with nodular iron splayed caps. Im going to be running the stock stroke and 4.030 bore also. but it will be fed by my ATI. Im just sitting back reading and wow,those are some impressive numbers on the stock block. Im wondering how much was put into block prep to get those blocks to hold together under that kind of power. I wonder if it is up in the bowtie block price range. If I do plan to go with a stock block how much wall thickness should I look for?Or in other word what is the recommended thickness i shoudl have? And what in terms of block prep would I expect to do? Just a note it will be street driven so I am weary of running block filler as I dont want to run hot. Would straight Oliver caps and arp studs be enough for the bottom end, or will the stock 4 bolt caps with studs work well?Thank you for the replys.
SStrokerAce
11-19-2004, 04:22 AM
Well most of them have blown up in that range.
Figure to get a block that is prepped as well as a Bowtie it costs about the same amount if you include the price of the block.
Block fill is not going to raise the temps too much anyways and if you do run a stock block the smallest bore you can put in there is the best, like a 4.010"-4.020" bore because it gives the most wall thickness.
BTW don't stick with a 4.030" bore on a Bowtie, please. 4.125" pistons are the same price and your heads will love you for the head flow. Plus that block can go to 4.190" so no need to worry about wall thickness.
"Today we build all of our 565ci and larger bracket engines with 4.600-inch diameter cylinders. The simple fact is that big bores produce "free" horsepower. There is no appreciable difference in the prices of 4.560 and 4.600-inch pistons, so why not get all the cubic inches that you can? An engine that produces nearly two horsepower per cubic inch will gain almost 20 horsepower at no additional cost by increasing its displacement by ten cubic inches - the difference between 4.560 and 4.600-inch diameter cylinder bores. The bigger bore diameter also unshrouds the valves and improves breathing, thereby adding even more power. With a siamesed-bore block, the difference in cylinder wall thickness between a 4.560 and 4.600-inch bore simply isn't worth worrying about."
It's Big Blocks but the same things apply.
Bret
AdioSS
11-19-2004, 01:24 PM
HPE left their cars outside overnight at the track and they think somebody sabotaged a few of them. Rick's turbo was messed up. They got a new turbo in the car and have dyno'd it again. Before Thunder they were pulling a bit over 950rwhp. This time they are over 1200rwhp :D Anybody want to guess what that is at the crank? The car has a glide and a 9" with 30x10.5 tires.
Fast Caddie
11-19-2004, 03:28 PM
Oh ok... thank goodness. I was a bout to be real sad..... LT1 block over 1200rwhp is awsome. I've always believed that the LT1 would go further with a turbo over a SC.... seems like they are a little easier on the block and bottom end due to less torsion and harmonics.
Go get those 7s Rick!!!!!! wait a minute.. if he gets there, would that mean the fastest LT1 would be faster than the fastest LS1? (or LS_ variant)
SStrokerAce
11-19-2004, 07:13 PM
HPE left their cars outside overnight at the track and they think somebody sabotaged a few of them. Rick's turbo was messed up. They got a new turbo in the car and have dyno'd it again. Before Thunder they were pulling a bit over 950rwhp. This time they are over 1200rwhp Anybody want to guess what that is at the crank? The car has a glide and a 9" with 30x10.5 tires.
If a rod goes out the side of the block it still didn't hold the power.
Anything over about 900hp is going to be a motor that you have to look after like a two year old walking around on the freeway in LA if you want to use a stock block. Unless you get off yanking motors in and out of a car and checking the rods and bearings and everything else I wouldn't go that route.
I'd love to see him run 7's, probably would have cost less money to do a Bowtie block from the start though.
Bret
Fast Caddie
11-19-2004, 07:43 PM
Bret
LOL, good point. I guess Rick will just have to show us what the LT block is really made of.
Have you seen the limits of the Motown or the Dart iron eagle blocks? Seen any blown up just due to shear power? Both are slated to take 2000 crank hp with ease. Curious to know if those claims are proven true.
OneFlyn95z28
11-19-2004, 10:14 PM
Last I heard Rick kicked a rod out the side of the block. He Dyno'd 1250RWHP the day before with the 101mm turbo
amean94ta
11-22-2004, 03:58 AM
Have you seen the limits of the Motown or the Dart iron eagle blocks? Seen any blown up just due to shear power? Both are slated to take 2000 crank hp with ease. we had a dart's main webs break it was in one of our pro mod cars (actually the former owner of krs) all three stages on n2o came in at once off the line estimated 2200 hp but the callie's crank survived :eek:
PROCHARGEDIROCZ
11-22-2004, 09:30 AM
Well here is what I found out . I talked with 2 builders in my area. One Reids, and the other Greg Hekimian. Reids said to starts with a 2 bolt then splay cap it and thats it. I mentioned block fill he said flatly you will over heat on the street. Anyway I didnt like his prices and he was really funny about pricing as he jacked up the price $500 dollars for machine work since I spoke with them last week before I visted his shop this week, Reids is not a very stand up guy, He might do good work but I just dont trust him, thing is he doesnt like to put down work quotes on paper, so he has the leyway to screw you on pricing. Now Greg on the other hand, was a complete 180 turnaround from Reids. I viseted him at 4 on Sat, I spend over 4hours at his shop. He went through everything and answered all my questions not to mention some of the sick motors he has done and has there, Plus some trick aftermarket parts I have never seen before. He really knows his stuff. His recommendation was to buy a new casting and block fill it up to the outlets for the water pump and keep the stock 4 bolt configuration. He showed me motors he had built with this same prep pushing over 650hp.And he said I will run colder on the street. Two different opinions.Gregs I seem to believe much more. Id recommend him ,very knowlagable and most important honest.
chucks97ss
11-22-2004, 11:43 AM
As far as I'm concerned, Rick's motor did not let go for anything related to the motor or it's strength. I personally believe it was after the turbo went out, it put a lot of metal through the intake and into the motor. Which is why the bearings got wiped out. We're building a new motor for it right now, and yes it's still an LT1. We're changing a few things, and it should be interesting to see how/if this one holds up to the new 1200+ hp tune ;) It is correct that the best pass we made was on the conservative tune. So if we can get this car to work, and the motor to hold, we WILL be in the 7's with it next season.
Chuck@HPE
SStrokerAce
11-23-2004, 12:56 AM
Good advice if it's a LT1, still think a Bowtie or aftermarket are worth the $$$
Bret
PROCHARGEDIROCZ
11-25-2004, 09:34 AM
SStrokerAce,The block in question is not a LT1. I do agree the Bowtie is worth the extra $$$. Any way it is one of Chevys new Bowties,the Sportsman block., and it is not as expensive as the bowties. The one piece rearmain seal sportsman goes for around $1800. I think its a deal. .170 thick walls at evena 4.190 bore, priority main oiling, nodular iron splayed caps.I agree a good foundation for a blown small block.Anyone own one here?
SStrokerAce
11-25-2004, 01:31 PM
I knew you were not reffering to a LT1, hence "Good advice if it's a LT1"
A Sportsman is a Bowtie, it just comes CNC preped with Nodular Iron Main caps and not 8620 ones like a 24502503 Bowtie Block.
Same Block casting (184 Casting), same CNC work, different caps and a MAX RECOMENED BORE OF 4.155" and it has a lower HP rating from GM but that doesn't really mean squat. The 8620 steel capped version Duttweiler runs 2,200 HP though so a 700hp rating is pretty conservative.
Yeah any of the Bowtie blocks are a great piece, BBC, SBC Sportsman or Racing Blocks. I have a few Bowties in the shop.
Bret
biggtime
11-26-2004, 12:07 AM
Not to highjack this thread but I am approaching this same issue. I currently run a blown SBC making just short of 700 to the wheels. I blew a blower up and when i dissasembled it to clean it I noticed my main caps were moving around. I have a 4340 1 piece seal crank so my block choices are limited to stock or the bowtie. My current block is a 1989 1 ton 4 bolt block not filled. I have a 4 bolt 86 block i was thinking of filling and using the milidon straight 4 bolt to splayed 4 bolt caps. I am changing the intake and intercooler so I think i am going to end up around that 1000 crank HP number. So do we all agree that the *magic* number is 1000?
Boost It!
11-26-2004, 01:07 AM
i think the *magic* number here the size your *ahem* :D
my expierence is blocks are waaaaaaay to unpredictable to put down a number. SO MANY factors.
New or used: used blocks seem to hold up a good amount better
cyl wall thickness
rpm
balancing
even engine mounts make a difference.
I saw an alum motor rip off at the motor mount (cracked off the "tab" for motor mount)
everything does. everything!
PROCHARGEDIROCZ
11-27-2004, 06:53 PM
Bret
Brett, I only said it was a new Bowtie in terms of its a new aftermarket block to feature the 1 piece rear main seal.I just wish Dart, or World would step up and offer them too.What do you get for a Sportsmans block part #12480174
