ianwells100
11-18-2004, 12:31 AM
just a quick question
i just got my car back from the body shop, (had someone hit my front end - not that bad, all body work) - but now i have a couple of problems, when i start the car from a stop, and if i let the rpms drop a little low (not stupidly low), the volt meter will drop really low, the lights will dim, but then it will go back up...
under normal driing all is well, the charging system works fine, etc... except for when i use the brakes, the headlights flicker, and the dash lights do the same (the volt meter drops a very little bit)
what would u say the problem is? bad grounds, need new alternator, need new battery??
the alternator was replaced last year, and i have no stereo in my car right now...
-edit: oh yeah, also on this past sunday, early in the morning, for my 2 minute drive to work, my abs inop light came on, and my emergency brake light stayed on (the e-brake was down).... yet later that day, after work, all was fine again in that regards
thanks for any help
thanks for any help
