Buck89RS
11-17-2004, 12:37 PM
What is the best way to empty my gas tank? I cant seem to get a hose in the filler to siphon it out so now what?
-Buck
-Buck
Gas Tank QuestionBuck89RS 11-17-2004, 12:37 PM What is the best way to empty my gas tank? I cant seem to get a hose in the filler to siphon it out so now what? -Buck OutKast 11-17-2004, 01:16 PM most newer tank /filler necks have made just about impossible to siphon it out. My best suggestion would be to disconnect the fuel line at the filter and turn on the pump. Might not get it all out but probably more than a siphon would do. HBHRacing 11-17-2004, 01:55 PM do to check balls it's hard to stick a hose in the filler necks. you can jump the prime connector with the feed line unpluged at the filter but it puts a lot of strain on the pump. Why do you need to empty the tank? Buck89RS 11-17-2004, 02:07 PM Dead gas. Has been sitting since 96. -Buck HBHRacing 11-17-2004, 02:34 PM Drop the tank. Your gas is no longer a liquid. It's now a thick green sludge. Get a new pump, sending unit, filter and have the tank steam cleaned. The injector might be damadged as well. | ||
