Mystic97Z 11-16-2004, 02:49 PM here's the scoop, wasn't getting too much responce in lt1 tech section
97 lt1 le1 head/cam package, fully built top end.
threw a rod last weekend.
i need to do something with the bottom end so it doesn't break again,
what can i do? i don't want to put -new- stock parts in it, do i need forged parts?
i was under the impression that you could put a 383 stroker crank/rods/pistons in a stock lt1 block, w/o boring it, am i wrong?
thats what i'd like to do, if not what are my other options?
basically i'm in need of a crank/rods/pistons, forged, but i don't have the $$ to bore my block..can i get forged parts w/o boring my block?
thanks a ton for any help..
-Jason
texlurch 11-16-2004, 05:09 PM First thing to determine is why it threw a rod. AS long as the block is undamaged and the bore is good, then yes you can just hone it and toss in a new bottom end. Plus it saves you an overbore for the future. If you are going forged, then there is a good chance that you can rerun the standard bore, since forged pistons run a little more clearance than the stock hypercraptic pistons did.
SStrokerAce 11-16-2004, 11:38 PM Problems I see:
1. Is the lack of pistons for a stock bore, at least good quality ones.
2. Not a new surface finish for the rings so the piston to wall clearance could be loose if you stayed around 4.000"
3. Not being able to set the piston to wall clearance.
4. 4.010 or 4.020 only costs a little bit to do and it's done right the first time, you have to put new cam bearings in the motor anyways so the added money for the boring to get the cylinder correct is well worth it.
5. Not doing it right the first time costs more money in the long run.
6. A LE1 package is not designed for a 383 so you will be down on power and RPM with a 383, so basically you wasted your cash on the wrong heads. I hate to see you get bad results and think that because it's a stroker it should make more power. If you wanted to do a 383, do it right send the heads back to Lloyd for him to make them work better with a 383 and get a cam for the 383 with those heads. If you need a new LT1 crank they are cheap, I have a buddy with 3 of them and it wouldn't be to hard to polish that up and send it to you.
7. Forged parts are not the place to spend the money. A set of Scat or Eagle I beam rods (which are forged) a stock LT1 crank that you have the journals polished on, and a set of good 4.010-4.020" pistons. By some decent rings and some bearings and have the machine work done right.
8. If you were the guy with the pictures of the broken rod, it's because you ran out of oil on that rod and spun the bearing. You didn't have too much power, probably just something in the motor or in the oil that caused that to go boom.
9. Good block work and assembly is worth more than Forged parts in keeping your motor together. If the machine work is junk and the forged parts are good you just spent a lot of money to break the forged parts because the tolerances are off and clearances are incorrect.
Good article for you to read about just throwing a bigger crank in the motor because it needs to be rebuilt......
http://www.rehermorrison.com/techTalk/15.htm
Good Luck,
Bret
Boost It! 11-17-2004, 03:50 AM Scat is also another great alternative for a crank. really cant beat their 9000 cranks for $189
damn strong too. rumors say stronger than GM's forged crank but who knows :)
Mystic97Z 11-17-2004, 02:17 PM ok, thanks for the help
i will not stroke it, so could i just polish my stock crank and re-use it? buy new rods and pistons? i don't now that 4.0 and 4.01 measurment stuff, the first time we rebuilt the lower end, we re-used the stock crank/rods/pistons and just put new rod bearings/main bearings/and piston rings on, we also honed the cylinders.
my dad took the oil pan off last night and said the block wasn't damaged...so i can re-use my stock crank, just get new rods/pistons and hone the cylinders?
thanks
-Jason
SStrokerAce 11-17-2004, 02:38 PM ok, thanks for the help
thanks
-Jason
Might be able to polish the crank, depends on how much the spun bearing did to it.
You've rebuilt this motor once before?
Bret
PROCHARGEDIROCZ 11-18-2004, 12:40 AM Scat is also another great alternative for a crank. really cant beat their 9000 cranks for $189
Please dont take this the wrong way.I wouldnt for the life of me put a Scat crank in my engine if it was given to me for free.Now before anyone jumps all over me, especially the people who own these cranks and will tell me they know so and so pushing x amount of HP for x amount of time.Scat at this very time is being sued in a multi million dollar class action suit.Seems their 4340 steel is not even close to being what they advertize it as,and they have been found out.And an inside source has told me their standard weight 4340 steel cranks go out the door costing under $150 to machine and forge.So any knowlageable person who know the cost of quality steel and machining cost can attest that the chinese made Scat cranks are junk, and cannot be 4340 steel. Spend the extra dollars and get a Callies,Cola or Lunati crank, just isnt worth it to take the chance. This is one place where buying american pays off.
atljar 11-18-2004, 12:59 AM Might be able to polish the crank, depends on how much the spun bearing did to it.
Bret
Ive always read as a general rule of thumb, "if you can feel a groove in the crank journal with your fingernail, its trashed".
Mystic97Z 11-19-2004, 01:47 PM ya we rebuilt the engine about 10 k miles ago, everything was fine until this happened, went through the lower end, new rings/bearings.
my dad looked at it and he doesn't think lack of oil was the problem, he said the crank wasn't too torn up, we'll see what happens. i guess i'll put just a regular lt1 eagle crank/rods/pistons in it ?
thanks
-Jason
i'm also going to be steping up my cam, it won't be a daily driver anymore so i'm going alot bigger..
SS MPSTR 11-19-2004, 03:06 PM Please dont take this the wrong way.I wouldnt for the life of me put a Scat crank in my engine if it was given to me for free.Now before anyone jumps all over me, especially the people who own these cranks and will tell me they know so and so pushing x amount of HP for x amount of time.Scat at this very time is being sued in a multi million dollar class action suit.Seems their 4340 steel is not even close to being what they advertize it as,and they have been found out.And an inside source has told me their standard weight 4340 steel cranks go out the door costing under $150 to machine and forge.So any knowlageable person who know the cost of quality steel and machining cost can attest that the chinese made Scat cranks are junk, and cannot be 4340 steel. Spend the extra dollars and get a Callies,Cola or Lunati crank, just isnt worth it to take the chance. This is one place where buying american pays off.
Interesting...have some proof to share? Links, etc. What court is the lawsuit filed in?
OldSStroker 11-19-2004, 05:56 PM Please dont take this the wrong way.I wouldnt for the life of me put a Scat crank in my engine if it was given to me for free.Now before anyone jumps all over me, especially the people who own these cranks and will tell me they know so and so pushing x amount of HP for x amount of time.Scat at this very time is being sued in a multi million dollar class action suit.Seems their 4340 steel is not even close to being what they advertize it as,and they have been found out.And an inside source has told me their standard weight 4340 steel cranks go out the door costing under $150 to machine and forge.So any knowlageable person who know the cost of quality steel and machining cost can attest that the chinese made Scat cranks are junk, and cannot be 4340 steel. Spend the extra dollars and get a Callies,Cola or Lunati crank, just isnt worth it to take the chance. This is one place where buying american pays off.
As SS MPSTR said, please come forward with specifics. I'm a knowledgeable person on materials and manufacturing of metal parts, and I cannot conclude that your statements are true.
FWIW:
It's easy to determine the chemical composition of a piece of metal. The Chrome, Molybdenum, Nickel and Carbon percentages, the main alloying elements in 4340, can be determined by a lab.
Nearly 40% of the steel produced in the world is produced in China. It is very difficult to buy 4340 originally melted in the USA. I'm not saying all Chinese steel is good or bad, nor that they are 40% of the 4340 source, but their output is prolific.
There is 4340 and also Aircraft Quality (AQ) 4340 (as well as other alloys). AQ steel is most often double vacuum melted, x-rayed or other ways tested for inclusions, laps, seams, etc. that "commercial" quality steel doesn't see. I believe that lower priced 4340 parts are probably not made from AQ steel. Very high end producers will advertise the fact that they use AQ steel, but you will pay well for their products. AQ steel isn't inherently stronger, it's just "purer" in composition, cleanliness and consistency.
I'm not defending Scat, but the stuff we have seen from them has been everything they claim it to be. The 9000 cast cranks (completely produced in China from the markings) that we have measured have been spot on. Other forged parts that were machined domestically have also been fine.
It is entirely possible that a lot of steel is falsely certified by the steel dealer. There are unscrupulous folks in every industry. There have been cases where flight-critical aircraft parts were falsely certified, which is scary to me. This could have happened in the case you mentioned. It has certainly happened to other producers/sellers of aftermarket parts.
There is no assurance that stuff produced in any specific country (USA or otherwise) has guaranteed good quality. Today at lunch a guy was showing us some T-handle rocker arm cover hold downs sold by a well known domestic manufacturer that he had just purchased. "Made in the USA" was stickered on the blister pack. The external turning was pretty, as was the anodizing. When I handed the parts to one of my CNC lathe operators, she was shocked to find the tapped end had countersinks which varied almost 1/8 inch from part to part. She works in thousandths (.001) and "tenths" (.0001) daily, and thought the parts were "junk machined". These were $4 each retail, and Made in the USA. Functional, sure, but high quality? Not IMO.
My highly opinionated $.02
PROCHARGEDIROCZ 11-19-2004, 06:41 PM I cannot give detailed specifics.But the story was first heard on the thirdgen site. I have spoken with the said individuel who is involved in the suit.He should be posting this in the next few weeks. Seems Scat is being sued to the tune of 130 million dollars, (I think) for misrepresenting its parts as "Made in the USA" which they are not,they are just machined here in the USA. Thing is the individuel had the equipment and technology to examine the said broken parts and found the metal to be substandard steel. Not even close to 4340 specs. Trust me you will all hear about this in the upcomming weeks.This is all I know at this time.
SS MPSTR 11-19-2004, 08:29 PM I cannot give detailed specifics.But the story was first heard on the thirdgen site. I have spoken with the said individuel who is involved in the suit.He should be posting this in the next few weeks. Seems Scat is being sued to the tune of 130 million dollars, (I think) for misrepresenting its parts as "Made in the USA" which they are not,they are just machined here in the USA. Thing is the individuel had the equipment and technology to examine the said broken parts and found the metal to be substandard steel. Not even close to 4340 specs. Trust me you will all hear about this in the upcomming weeks.This is all I know at this time.
There is a significant difference between the representation that something is "Made in the USA" and whether the products they sell are materially what they represent them to be. At first blush, a $130mil complaint seems pretty hefty for a broken crank/rods (I don't know specifics) - how many engines could you replace with 1% of that amount?
As OldSStroker said, I too have used the 4340 Scat stuff in both stroker engines I've built, and both were everything Scat said they were, and well within spec to boot. I'll reserve judgement until I see the complaint filed with the court.
Mystic97Z 11-23-2004, 03:44 PM ok, well i called about having my block bored, and its in the budget, so i've decided to go w/ a 383 stroker kit, to maintain a lil more drivability over the 396. now where can i get a good 383 rotating assembly? what are things to look out for, i was looking into the eagle 383 lt1 kit, some people rave about it, some people bash it, i guess i'll find that w/ every kit huh?
-Jason
some one also recomended crower, i can't find a complete -lt1 383- kit by crower online??
PROCHARGEDIROCZ 11-25-2004, 09:58 AM Now this is only my opinion first off. If I was in your position, I would be looking at the top 4 for cranks. Callies, Cola, Lunati, and Crower. All high quality made parts, and more than likley you will not hear any bad things about their quality. My builder, when I went to his shop told me the Eagle stuff is ok, but all the time when he gets the rods(SIRs) and the cranks from Eagle , always,always , their is at least 3 or more out of round big ends on the rods and the crank journals are off,so he has to clean them up, which adds to the cost. If your builder doesnt know to check this you may be in for some problems. If you are looking at rods,and you like the price of the Hbeams, just remember that most are manufactured in China,even the expensive H beam from Manley. Depending on your budget, Lunati, Crower sportsman, or the more expensive Oliver may be the ticket.You didnt specify NA or Blown. I think at this point, to forgo further problems look into high quality machine work as the best parts in the world wont survive shoddy machining and assembly.It might be a little more expensive up front but will pay for it self in the long run in reliability. There are many builders who can supply a short block already machined and assembled, just add your own stuff to finish. This might be another route.I am not familer with the LT1s at all. But Im sure alot of knowlagable people here can chime in and steer you in the right direction, as I assume their are more than a few here running 383s. Just remember, you might save $$ on the crank, but the savings will negate it self if you spend $200+ in mallory to get it to balance. I just got a Cola crank spent $650 for it, but since the price in Steel is going up the price has jumped 45 dollars since I purchased it. Same thing with my Oliver rods, I paid $699 for the forged units, they are now $825. I think a Callies crank goes for $795. To put in comparison, the Eagle forged is around $600 and sometimes it hit or miss on the journals,plus if you spend $200+ in Mallory balancing it+ if the journals are off, you are already around the price of the others. Samething with the Cast steel from Eagle, sure its cheap, at around $200, but if it cost you $400 to balance it is it still a deal? More than likley your best bet would be a balanced and matched rotating assembly, from either Callies or Lunati.. Hope this helps.
SStrokerAce 11-25-2004, 01:52 PM Now this is only my opinion first off. If I was in your position, I would be looking at the top 4 for cranks. Callies, Cola, Lunati, and Crower. All high quality made parts, and more than likley you will not hear any bad things about their quality. My builder, when I went to his shop told me the Eagle stuff is ok, but all the time when he gets the rods(SIRs) and the cranks from Eagle , always,always , their is at least 3 or more out of round big ends on the rods and the crank journals are off,so he has to clean them up, which adds to the cost. If your builder doesnt know to check this you may be in for some problems. If you are looking at rods,and you like the price of the Hbeams, just remember that most are manufactured in China,even the expensive H beam from Manley. Depending on your budget, Lunati, Crower sportsman, or the more expensive Oliver may be the ticket.You didnt specify NA or Blown. I think at this point, to forgo further problems look into high quality machine work as the best parts in the world wont survive shoddy machining and assembly.It might be a little more expensive up front but will pay for it self in the long run in reliability. There are many builders who can supply a short block already machined and assembled, just add your own stuff to finish. This might be another route.I am not familer with the LT1s at all. But Im sure alot of knowlagable people here can chime in and steer you in the right direction, as I assume their are more than a few here running 383s. Just remember, you might save $$ on the crank, but the savings will negate it self if you spend $200+ in mallory to get it to balance. I just got a Cola crank spent $650 for it, but since the price in Steel is going up the price has jumped 45 dollars since I purchased it. Same thing with my Oliver rods, I paid $699 for the forged units, they are now $825. I think a Callies crank goes for $795. To put in comparison, the Eagle forged is around $600 and sometimes it hit or miss on the journals,plus if you spend $200+ in Mallory balancing it+ if the journals are off, you are already around the price of the others. Samething with the Cast steel from Eagle, sure its cheap, at around $200, but if it cost you $400 to balance it is it still a deal? More than likley your best bet would be a balanced and matched rotating assembly, from either Callies or Lunati.. Hope this helps.
Few points to add to that....
If the guy is looking to see if boring a block is in his budget I don't think he has the money for a forged crank lol.
Have you YOURSELF ever measured a Eagle crank that is not right? Every one I have ever checked has been within +/-.0001 journal to journal. They have gotten much better with indexing and journal sizes over the years. On top of that, they give you a target bobweight for the crank and the thing will balance without heavy metal if you are below that, well unless you screw up and drill out too much. ;)
I wonder if Manley H Beams actually are made in China? If they are such junk becuase of this I wonder why ever Sportsman and Bracket motor that Reher Morrison makes has them in it?
Now when you get into cheap forged rods like a Scat I or a Eagle SiR there are times when you have to throw them on the hone to clean up the big or small end of the rod. Usually it's one out of every set and only the pin bore and for the price of those rods, it's still a deal for what you get. At that point the cost and proper application of the parts doesn't warrant something like a Oliver or even a Eagle H beam. A $250 set of rods is a dam steal, and a few minutes of time on the hone to fix them surely doesn't warrant a $800, $1200 or even $400 set of rods.
Funny thing on the cheap cranks like Scats and Eagles, if you go throwing tons of heavy pistons and rods on them then heavy metal would be needed, but if you match them with parts that are similar in use and strength you are usually close. I don't see the point of a guy spending $1600-$2000 on a rotating assembly where he could get buy with a $1000-$1200 setup and $100 (at the most) of extra labor to make it work.
I've used both $1200 cranks and $200 cranks in builds, $1200 rods and $250 rods and $1300 piston sets and $260 piston sets, Junk stock blocks and $2500 Race Preped Bowties. The same care needs to be taken with all the parts, but they all have their applications for the budget and use of the motors.
On the other hand it's good that the guy you use checks all the parts. Cheap parts do add labor price to a build, no doubt about that. That's why things like Mahle pistons are so nice for a build.
Bret
PROCHARGEDIROCZ 11-27-2004, 07:46 PM Few points to add to that....
Bret
I have my self never measured a Eagle Crank,never had a chance too, for two reasons.I never purchased one, and have not done any kind of rebuilds with them , I just talk with builders who have alot of experience with them. They like you dont completly knock Eagle Quality, but the resounding fact is without a doubt, that Eagle is not up to par on its specs.
Now, I did not make the statement Manley is junk because it is made in china. I just made the statement, that they are made there, for anyone who doesnt want to purchase the Scat or Eagles thinking it is a made in china subpar H beam rod, and think that you are getting a made in america top of the line Hbeam, which comically is much more expensive than the before mentioned two companies. Manley H beams are made in China, have been a for a long time, most likley come out of the same building as the Scat and Eagle stuff.Call them up they will tell you they are only machined here like the other 2.I have no opinion or comment on why Reher Morrison uses those rods in their motors. But Reher Morrison is one out of thousands that builds motors, each has their preference Manley seems to be his, but some of his motors feature C&A rods as well. I guess the point Im trying to make about the China made parts are that if you speak to 100 people who own these china made parts wheather it be cranks or rods, its almost a 50/50 problem/ no problem outcome. When in comparision the american made parts from the big names like Callies, Crower, Cola, Lunati, C&A, Oliver, you hardly ever hear of problems in terms of specs, or problems with balancing, or problems with the finish work. I dont know about anyone else but If I pay $600 for a crank, and it is still not 100% out of the box Im not to happy a person. Eagle Sirs are good for a budget motor, thats it. But I think a better bet is the PM Gm rods , they are cheaper than the Eagles and made in the USA.
On the balancing, the Eagle and Scats counterweights tend to differ from each other vs the Callies, Crower, Lunati and Cola. A few grams not properly machined here and there add up to a lot of finessing of the crank to work, which like you said can add up in the long run.
I think the resounding fact here is the word "budget" and "quality" should not be in the same sentence. If you are looking for a cheap rebuild, and cheap machining cost, you will end up with a cheap motor which will cost you what you should have paid for the better quality machining and parts in the long run when it spins a bearing or the caps walk. I have learned the hard way," You get what you pay for".
Boost It! 11-27-2004, 08:21 PM we use scat in at work in a damn near full blown racecar (think 7 liter twin turbo, 8psi, NASCAR STYLE intake/heads)
no problems with them
