Popping noise when i brake sometimes???
Old Nov 15, 2004 | 11:15 AM
crAzy95z28's Avatar
what is this? not everytime but sometimes when i brake i hear a pop noise comming from the front of the car!!!
any clues?
Randy
Old Nov 24, 2004 | 05:43 AM
MentalCaseOne's Avatar
Re: Popping noise when i brake sometimes???
Its your Brake pad moving back and forth inside the Caliper. as you move on reverse... the pad will slide in one direction ... then you drive forward and when you apply enough pressure it will slide in the other direction till the calliper stops it... and you hear that little pop.
I fix mine with some of that grease (for lack of better words) that they sell to eliminate brake noise at the auto parts... when it dries it glues the pad to the other metal parts... or at least keeps it from moving
When the pads were manufactured.. they were made about a millimiter too small... so they have a little play.
If that is not your problem then I have no idea what is...
Marvin
Old Nov 24, 2004 | 12:36 PM
crAzy95z28's Avatar
sounds about right!!! ill check it out!
thanks
Old Nov 25, 2004 | 01:04 AM
wbna0149's Avatar
A loose caliper or caliper pounting bracket comes to mind also. Check for proper bolt torque
Z28Freak86
Apr 30, 2024 05:37 PM
AdsoYo
May 2, 2018 03:21 AM
Gtpguy
Jan 26, 2015 04:50 PM
Red97LT1
Aug 7, 2002 05:45 PM
