LPE_wannabe
11-11-2004, 10:15 PM
what MM back spacing do i need for 18x9.5??? i searched for it but couldn't find it...thanks
What MM back spacing???LPE_wannabe 11-11-2004, 10:15 PM what MM back spacing do i need for 18x9.5??? i searched for it but couldn't find it...thanks LPEdave 11-12-2004, 01:55 PM Usually backspacing is measured in inches, maybe that's why you're not finding it. A 9.5" wheel on a 4th gen needs about 7" of backspace, that would be 178mm. Dave LPE_wannabe 11-12-2004, 05:54 PM well the wheels i want (C6R's) 18x9.5 + 56mm so i was assuming that was the back-spacing...guess i'll just call em when i'm ready to buy Injuneer 11-12-2004, 06:46 PM In the wheel you mentioned, 56mm is the "offset"... the distance the mounting face is moved out ward from the centerline of the wheel. That is the correct offset for a 9.5" wide wheel on a 4th Gen. Anything from about 45mm to 56mm will work. The 56mm offset will give you a backspace of about 7.4 - 7.5". LPE_wannabe 11-15-2004, 01:16 PM In the wheel you mentioned, 56mm is the "offset"... the distance the mounting face is moved ******d from the centerline of the wheel. That is the correct offset for a 9.5" wide wheel on a 4th Gen. Anything from about 45mm to 56mm will work. The 56mm offset will give you a backspace of about 7.4 - 7.5". ohhhhhhh...that makes more sense...thanks!!! | ||
