First gen SBC heads on an LT1???
Sleeper_Z
11-11-2004, 08:44 AM
I just got an amazing deal on a set of HVH 23 degree race heads and I was wandering if it would be at all possible to convert them to the revuse flow coolent system to work on my LT1. The heads are 69cc 2.08/1.65s, fully ported and flow around 330s on the intake and mid 200s on the exhaust. I would really like to use these heads and the intake bolt differance is no big deal sence I will probibly have to go with a sheet metal intake cause the stock LT1 intake doesnt have enough material to it to port match to these heads. If anyone has any info please post. Thanks very much!
Jeremy
crash4cyl
11-11-2004, 10:43 AM
Going to from SBC to LT1 may be harder than the LT1 to SBC. I know thirdgen.org has a lot of guys using LT1 heads on SBC motors, but I haven't heard of the opposite. couldn't hurt to check it out.
Chris
Injuneer
11-11-2004, 11:06 AM
You might actually have better luck with this on LT1 Engine Tech.... there are people there running Gen 1 heads on the LT1.
n2oblkz
11-11-2004, 03:14 PM
Sleeper Z, email sent about this topic.
n2oblkz
11-11-2004, 04:33 PM
Here are a couple of links that can help you out.
Ben
http://web.camaross.com/forums/showthread.php?t=230845&highlight=LT1+head+conversion
http://web.camaross.com/forums/showthread.php?s=&threadid=90052&perpage=15&pagenumber=1
Eff
11-11-2004, 06:55 PM
I've heard of people doing it. Guess it wouldn't be a bad idea. Since they would retain heat better than aluminum heads.
hey can you send me info on it too? mreff555@hotmail.com
Sleeper_Z
11-11-2004, 07:51 PM
Eff,
The heads I am wanting to use are aluminum. They are HVH race heads. The links that were posted didnt really give me any good info that I was hopeing for. If anyone can help me out Id appriciate it. Thanks
Jeremy
ltlhomer
11-11-2004, 08:03 PM
Eff,
Jeremy
You can get the conversion done for around $250 so it's not bad at all. PM me if you want to know who I would recommend.
Take care,
Sean
nateh
11-11-2004, 10:04 PM
I ran some converted Brodix -10 heads on my car until they broke this year. Conversion is not that bad if the shop knows what to do. Weld up coolant passages on the intake side. Add oil drainback holes, open new passages on the engine side, and open holes in the back side for the crossover tube. Machine the intake and deck sides flat.
OneFlyn95z28
11-11-2004, 10:10 PM
we were not even going to fill the holes on the intake side with my Brodix 18- heads ;) Instead of drilling the heads for the air bleed I was using back water passages ;)
Not that hard if a good shop does it ;)
Dave69Z
11-11-2004, 11:05 PM
I ran some converted Brodix -10 heads on my car until they broke this year.Till what broke? The heads? Related to the conversion?
Dave
nateh
11-12-2004, 11:47 AM
It's a long story. After a lot of trouble, I had everything working correctly and my car was running quite well. One of the valve seats broke, sending a piece into the combustion chamber. It dinged a piston and the head a little. The heads are easily repairable, but I need a new valve and I'd definitely want new seats. I decided to go back to the stock castings and I freshened the stock bottom end with new rings and bearings (and a new piston).
I had visions of fixing the heads and putting them on a new shortblock with a Victor EFI manifold. They would make some serious power. After the money I've spent though, I'm not going to use them. I even had a stainless y-pipe made to go with the headers. If anyone wants the whole kit (heads, springs, ARP studs, modified headers (ASM/RKSport midlength),braided stainless crossover tube, etc., I'll let them go for an insanely good price, just to get them out of the way.
