what kind of 1\4 # for vortec
Old Nov 10, 2004 | 12:20 PM
r103's Avatar
what kind of #'s should i exspect from stock motor, vortec super, headers, and gear. (95 m6 with slicks)
Old Nov 10, 2004 | 01:03 PM
carnutz's Avatar
Re: what kind of 1\4 # for vortec
Witch vortech, what boost, what gear etc...... If you expect a answer you need to FULLY ask the question
Old Nov 10, 2004 | 01:56 PM
tryintogofast's Avatar
buuuurrrnnn.....high 13's
Mike
Old Nov 10, 2004 | 02:01 PM
carnutz's Avatar
Originally Posted by tryintogofast
.....high 13's
Mike
With one of those late night TV vortex intakes and a 2.73 gear.....
Old Nov 10, 2004 | 02:05 PM
Like you said he didn't say what gear so...high 13's
I'll pull my guessimate down as soon as he gets more detailed into what mods he actually has.
Old Nov 10, 2004 | 02:29 PM
r103's Avatar
4.10 gear about 6 psi. i want something i can drive everyday.
Old Nov 10, 2004 | 02:35 PM
Anything else done to it such as cam/heads/head work/other bolt ons? We're gettin there
Old Nov 10, 2004 | 02:40 PM
r103's Avatar
STOCK MOTOR. headers, catback system, 4.10 gears and 6psi supercharger.
slicks. i ran 13.7 on street tires with just gears, homemade CAI, and exhaust.
Old Nov 10, 2004 | 02:56 PM
Geoff Chadwick's Avatar
To be cheesy, you gain .1 in the 1/4 for every 100lb you loose. It's like gaining 10hp. Gain 100hp and you technically should gain 1 second in the 1/4. With 6psi, that's somewhere toward 120hp, so just about a second. But by your times (13.7) with gears, cai and exhaust - that isnt too bad. 13.7 is one number, but the MPH will tell us a lot more. I'm guessing you were spinning a lot, and probably on slicks if you keep it together and traction is good, hopefully a mid 12.
Dont forget, slapping on slicks is only a start- but there are those with a 12bolt rear, slicks, exhaust, cai, and headers and gears that have taken an lt1 to 12 flat passes. But noting that you dont have killer suspension stuff, you probably cant launch it too hard (or want to, as you'll nuke the 10 bolt doing that) you should be running mid-low 12's... I'd guess... but driver skill will prove that or break it.
I'd say probably mid to low 12's with some good traction.
Mike
Old Nov 10, 2004 | 03:19 PM
r103's Avatar
thanks
Old Nov 11, 2004 | 09:37 AM
Originally Posted by Geoff Chadwick
But noting that you dont have killer suspension stuff, you probably cant launch it too hard (or want to, as you'll nuke the 12 bolt doing that)
Hehe 10 bolt. He's not going to break a 12 very easily.
Old Nov 11, 2004 | 01:10 PM
Whoops! Brain fart on that one
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
94Maroz28
Oct 27, 2015 04:38 PM
Hal Fisher
Sep 30, 2015 09:03 PM
karpetcm
Sep 29, 2015 10:08 AM
